#1 |
![]() Drives: MK5 GTI 2.0T DSG Join Date: Mar 2006
EVOMS V-FLow
100% Plastic construction (just like OEM uses) - This allows us to have smoother transitions of the 4 different ID's this intake requires that would be impossible to recreate with any metal intake system. Using plastic also allows us to control the inside diameter to tighter tolerances than with something like carbon where the molds are outer diameter dependent (hence the smooth finish on the outside). Our transistions occur over several inches to keep slopes less than 15% (very smooth flowing!!!) The plastic construction also retains less heat than other materials (which is why most OEM intakes are plastic).
We use a 6" venturi with a large custom filter that wraps around it. This does many things, but its main purpose is to increase the velocity of the air...hence V-flow This was originally used on our 911 996TT intake system and had such great results with power increases that we have been adapting it to all of our other lines as well! The filter was specifically designed on a flowbench with the venturi, to control and promote the beneficial characteristics of this unique feature. And lastly that I can think of is the heatshield/airbox that we have designed to supplement our kit. Our heatshield is also of plastic construction and shields the filter portion of the intake from the engine bay. The beginning half of the fresh air duct (OEM) is retained and fills the airbox with fresh cooler outside air. Not to mention it gives a really great finishing look to the part!!!! These should be out in about 4 weeks with a price of around $200 keep an eye out!!! ******This image is of our prototype intake, it is of metal construction and is 3 pieces where the finsihed product will only be 2 for smoother transitions as well. We have a replacement engine cover in the design stages so to keep a factory look after our intake is installed!!******* ![]() ![]() *****These dynos were done with an early version of GIAC (beleive before it was released) and our prototype piece. Our production intake will have better airflow than the prototype, and the current GIAC software is much more aggressive - just a disclaimer for the numbers on the dyno, they will be higher ;)******* ![]()
#2 |
FIA World Rally Car Champion
![]() Drives: 06 Subaru STI Join Date: Feb 2006
Not bad. Do you have any pix of the aftermarket engine cover designed to fit around this intake?
2006 Subaru Impreza STI ~ Blue/Gold stage II (re-flash & TBE) 350hp/385tq |
#3 |
we have several designs we are working on, so I don't have any official release yet. All I can tell you is they all utilize the silver plastic cover that snaps onto the airbox with the VW and GTI logo so that it keeps as factory look as possible. It will be powder coated wrinkle black to have a similar finish to the factory box. We will be posting pictures in the next few weeks before the release of the kit. It will be sold as just the intake, and the engine cover will be an option!
#4 |
That engine cover is a big plus. I hate popping the hood with everything exposed & looking a mess.
#5 |
![]() Drives: 2005 Golf MK5 GTI Join Date: Jan 2006
no option for RED powdercoated?
#6 | |
Touring Car Champion
![]() Drives: Tornado Red GTI MKV Join Date: Feb 2006
Golf MKV Forum Statistics: 38.225836958% of the users have actually posted at least 1 message. The other 61.774163042% leech. Calling All SoCal MKV Owners! Wanna show your GolfMKV.com Pride on MySpace? Buy Your GOLFMKV.com shirts and items here! |
#7 |
![]() Drives: 2006 GTI MK5 PKG 2, 18" Join Date: Mar 2006
VERY nice.
#8 |
FIA GT Champion
![]() Drives: 06.5 UG MKV GTI Join Date: Mar 2006
4 weeks huh.....man I hate to wait. So the factory inlet by the radiator support attaches to the heat shield? Did I read that right?
Anyone can drive fast in a straight line....it's going fast around corners that takes skill...
#9 |
Autocross Newbie
![]() Drives: MK5 GTI (Z4Z4) & Saab 92x Aero Join Date: Feb 2006
Sounds promising and the estimated price seems right on. I look forward to hearing and seeing more about this. and Hey - if you need a test GTI-->PHX right here! Hit me up
#10 |
There will be no RED powdercoated piece....they are plastic construction.
Yes the factory inlet near the radiator support attaches to the airbox/heatshield to provide airflow. No, we do not need a local GTI test car, but we are starting a local MK5 club, all of the members will receive additional discounts on our parts :) |
#11 |
shame PA isnt considered local :-P
#12 |
FIA GT Champion
Why not just a discount to MKV members on here? Please.....LOL
That is cool that the inlet hooks up to the heat sheild/airbox.
#13 |
Here is a photo of the prototype installed, you can see the incorporation of the factory inlet with the airbox. The production kit will not have a silicone coupler after the metal v-flow tag on the tube, it will be one piece until the intersection of the MAF housing. The airbox will have more rounded corners, and the engine cover will be a similar shape/size, retain the FSI turbo VW portion of the cover (the silver plastic piece that runs vertical on the cover) but the black portion will change to either a flat style, carbon, or other potentials.
#14 |
Nice & clean.....me likes
#15 |
Moderator
![]() Drives: '05 UG Golf 5 Plus Join Date: Feb 2006
me also
#16 |
![]() Drives: 1999 V6 Mustang Join Date: Mar 2006
Very nice
#17 |
Autocross Newbie
Looks good Anders, once you guys get these in production I'll drive up to Phoenix and get one installed. Keep up the good work!
#18 |
Rally Car Newbie
![]() Drives: GTI Mk5 United Gray Join Date: Feb 2006
Looks great! Any sound clips?
GTI MkV, United Gray, DSG, Pkg2 ug0021 |
#19 |
Autocross Newbie
nice. Looks like it means business.
Also, I'm all about an AZ MKV club... |
#20 |
No sound clips yet! We are expecting the first article in about 3-4 weeks. At this time we will be doing all our testing: Flow bench, dynos, data logging, photos, sound clips...etc.
We hope to have kits on the shelf ready to sell in less than 6 weeks, hopefully as soon as 4. We are waiting on our plastics guy, so it is out of our hands right now As I get updates and further along in the process I will absolutely keep everybody updated!***Everybody interested in a Arizona MK5 club send me an email: aberg@evoms.com, so that I can make a list and let you guys know of events we are planning! We are moving to a new facility (25,000 sq/ft) in june. We will have a huge open house at this time, we will be featuring a 2WD dyno, 4WD dyno, something like 10 lifts, machine shop, huge showroom, it will be awesome!*** |
#21 |
Rally Car Newbie
Kinda wish I lived in AZ.
#22 |
low
that is the sexiest intake yet!
| Thread Tools | |
