![]() Support GolfMKV by clicking this link to do your tirerack shopping, THANKS!
Thread Tools |
#1 |
Touring Car Newbie
![]() Drives: Rabbit 2007 Join Date: Feb 2007
Air Ride Questions
Ok, I am doing some major changes on my car for the next season and had a few questions, hoping some of you could help me out.
First question: How much should I expect to spend on air ride for my MKV Rabbit (Bags, Compressor, Installation). 2. How hard is it to maintain this kind of suspension? 3. Where can I have it done? Preferably in Quebec? If Not than in Ontario or Vermont, or NY, or NJ? Thanks! Alex
mk2 golf 1.8l - sold | mk3 golf 1.8l - r.i.p. | mk3 golf 2.0l - sold | mk2 jetta 1.8l - sold| mk5 rabbit - totaled | mk6 gti - sold |
#2 | |
Baggin aint easy
![]() Drives: 08.5 2dr TR GTI Join Date: May 2008
I am going to be bagging soon too! The cost depends on whether or not you have coilovers already, If you don't have coilover expect to spend anywhere from $2500-$3500(depending on the components you choose). If you do already have coilovers or you want to keep your stock struts and just bag them you can get away with spending aroung $1500-$2000(also depending on components). Maintence from what I've gathered is minimal, just check you air/water seperator every once in a while, look over the lines make sure everything is clean, and there are no leaks. Now I have no Idea where you can have it done since there isn't really a big crowd for air here on the east coast/Canada. Here are a few threads I highly recomend you read, there's lots of great information and can probably answer many of your questions, also go to www.vwvortex.com and look in the "air suspension" section, there are a lot of bagged vw's so you can see other examples. http://www.golfmkv.com/forums/showthread.php?t=55642 http://www.s10forum.com/forum/f30/pr...rabbit-342273/ http://forums.vwvortex.com/zerothread?id=3290513 http://forums.vwvortex.com/zerothread?id=3804237 |
#3 |
![]() Drives: Maxima Join Date: Mar 2008
Adjustable suspension requires very little 'traditional' maintainence work. Just make sure you DO IT RIGHT THE FIRST TIME.
I would DEFINITELY recommend investing in a watertrap between the compressor and the tank if your kit doesn't have one. Unless you want rusted valves/rusted tank. I've had air suspension on almost everything I have driven (except the current DD.) and only had to replace parts because of mistakes I made in the initial install. A good forum for you to learn a little about basic air suspension/fabrication would be streetsourcemag.com. The majority of the regular posters have EXTENSIVE modifications to the suspension of their vehicles, and LOTS of shops use their forum as a way to communicate (meaning finding a good shop in your area will be easier). I would highly recommend using an 8 valve setup as well. Even if you don't plan on going 'side to side', it keeps your suspension from slopeing during corners as pressure slides from left to right, or vice versa.
![]() I've got stance. |
#4 |
Touring Car Newbie
Thanks a bunch guys! I ll be checking out the links :)
Alex
#5 |
Baggin aint easy
actually....I just remembered. This place is in Toronto.
http://www.airassisted.com/ "Infrared" bought a lot of the components for his kit there, and I will be buying quite a few from there. You should check em out. |
#6 |
Formula 5000 Driver
![]() Drives: '08 MT BMP GTI Join Date: Jun 2008
Anybody know a rough estimate on many hours a full air ride install may take on average?
#7 |
07 GTI and 06 Passat
![]() Drives: GTI Passat Join Date: Nov 2006
should be 1 day affair or break it down to 2 days and with all the parts it could be done on a weekend
AJ DFWeuros.com |
#8 |
Touring Car Newbie
Really really really tempted... We have a big DUB community here in Montreal, but no MKV's on bags - someone s got to start :)
#9 | |
Driving on the wrong side
#10 |
cant spell or tipe!
about how much $$ ??
#11 |
what about oscar? isn't he in canada?
#12 |
Touring Car Newbie
Never heard of "oscar"
Also, Canada has the longest coastline in the world: 243,000 kilometres... NY/NJ is MUCH closer to me than... let's say British Colombia... in fact, I live only 1 hour away from VERMONT/NEW YORK boarder :)
#14 |
![]() Drives: 2008.5 VW GTI "TSI" Join Date: Feb 2009
Where can I get air ride installed in NEW YORK AREA long island would be the best????
#15 | |
www.eemilitia.com
![]() Drives: 07 BAGGED MKV Join Date: Feb 2009
All in all... if you do it correctly.. a rough estimate is about $2500-$4K not including install if your not doing it yourself.
![]() www.underwrapsautomotive.com www.underwraps.bigcartel.com CUSTOM DECALS & DESIGN WERKS |
#16 | |
#17 |
Formula 5000 Champion
![]() Drives: 10 MK6 GTI 6MT Join Date: Apr 2008
i'm located in south jersey and i have done air bag installations before. if anyone can't find someone closer to do it, let me know
| Thread Tools | |
