Diabel
2007 GTI, PK 2, DSG, CW
- New Jersey
I know that they sell nos that you cant put to the fuel tank together with the fuel. Did any of you tried it already? Im not sure what excatly that thing does.
Diabel said:I know that they sell nos that you cant put to the fuel tank together with the fuel. Did any of you tried it already? Im not sure what excatly that thing does.
Well not exactly.Anglewood said:A true NOS system raises power by increasing compression through introducing more cumbustible gases (02) into the combustion chamber.
slickvic said:Well not exactly.
In street racing, nitrous oxide (often just "nitrous" in this context) is sometimes injected into the intake manifold (or just prior to the intake manifold) to increase power: even though the gas itself is not flammable, it delivers more oxygen than atmospheric air by breaking down at elevated temperatures, thus allowing the engine to burn more fuel and air. Additionally, since nitrous oxide is stored as a liquid, the evaporation of liquid nitrous oxide in the intake manifold causes a large drop in intake charge temperature. This results in a denser charge, and can reduce detonation, as well as increase power available to the engine. :thumbsup:
gCHOW said:real slick, vic. :thumbsup:
i'm sure some of you watch this, but theres this new show on speed channel right now call street tuner challenge and they're actually modding a GTi. on that show EIP tuning is actually using NOX as an additional coolent for the intercooler. how they set it up was they programmed it so that at full throttle, or when a switch was hit, liquid NOX would be sprayed directly onto the intercooler. they claimed that the energy required to evaporate the NOX would actually result in significant increases in horsepower by decreasing the temperature of the compressed air some more.
i wonder if anyones actaully tried this.
Anglewood said:A true NOS system raises power by increasing compression through introducing more cumbustible gases (02) into the combustion chamber. Nothing you add to the tank short of liquid O2 could do this, but that is physically impossible. I haven't heard of a GTI with a Nitrous Oxide system yet, but would guess that the results would be good if used in short bursts.
Lates,
Connor
