Old 05-18-2010, 10:55 AM   #111
sbaker123
Drives: Volkswagen golf 1.6 fsi mk5
Can anyone tell me whether i can get 18inch alloys on my volkswagen golf fsi mk5.
225/40/18
5X112 ET 45
8x18
sbaker123 is offline   Reply With Quote
Old 05-23-2010, 12:38 AM   #112
artificialaspirations
Drives: 2009 jetta wagon
Originally Posted by RedRabidRabbit View Post
Ok, since there is a thread on here at least once a week (plus the tire thread also) about people asking for different combinations of wheel/tire fitments, I spent a few hours putting this chart together. If the mods want to make it a sticky or add it to the FAQ, I'm sure it would help out some people.
Couple points:
Everything you see below is a fairly conservative setup... But with that said, if you have four people and luggage in the car, don't come crying back to here when it rubs.
The tire sizes I have highlighted in yellow are fitments that will rub more often, mainly because there is no such thing as a 205/35R19 tire, which is what would be ideal.
If your offset isn't listed (34 or less) it's because it's not recommended (it was a stretch to even do 35 - 39), not because it won't "work". I haven't included any staggered setups for the same reason... Plus there are just too many variables.
great chart, but what about us lowly guys running stock 16s? Can I fit 225/55s on it stock suspension, or 245/50s?
artificialaspirations is offline   Reply With Quote
Old 05-23-2010, 12:45 AM   #113
RSMark5
GolfMkV Elite
RSMark5's Avatar
Drives: 06 Passat 3.6 4motion
a 245/50 would work depending on a lot of things. You wouuld need wheels with a good offset et38-42 aprox and you might need camber plates upfront. You might be fine if you roll the fenders but IIRC the major issue is strut clearance.
225/55/16 should be fine. Isn't that factory tiresize?
RSMark5 is offline   Reply With Quote
Old 05-23-2010, 12:58 AM   #114
205/55-16 is factory. I don't want to change wheels, I just like the way the larger tires plant he vehicle on the road. I don't know what rolling fenders is and don't care to add camber plates, just want to know the largest tires I can fit on the stock 16s. How about 205/60?
Old 05-27-2010, 05:38 PM   #115
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
Drives: MkV TR 5dr GTI
Hi guys,
Please need some HELP! I have a MkV GTI with 17" denvers, stock ride hieght.
I have a mate with a B7 A4 and I want his rims! They are 245/35/19 and I think a ET35 offset.
Will these fit on my GTI or is 245 too wide with that offset?
Any help is appreciated...
NahbutsGTI is offline   Reply With Quote
Old 05-27-2010, 05:44 PM   #116
Benjamin T
FIA GT Champion
Benjamin T's Avatar
Drives: 07 MK5 GTi DSG
Originally Posted by NahbutsGTI View Post
Hi guys,
what is the width of the wheel?
how close is your mate? will he let you test fit?
Benjamin T is offline   Reply With Quote
Old 05-27-2010, 05:50 PM   #117
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
225/40/18
5X112 ET 45
8x18
yes that will work.
Anyone know if 19 x 245/35's are to wide for a GTI?
Old 05-30-2010, 06:46 AM   #118
NahbutsGTI
EUROTHRASH
NahbutsGTI's Avatar
19 x 8.5 I think. he's a few hours from me so it's a bit of a pain...
Old 05-30-2010, 10:14 AM   #119
Benjamin T
FIA GT Champion
Benjamin T's Avatar
do you have a picture of the whee/tire as it is now? my uneducated guess is that a 245 will be fairly square on an 8.5" wide wheel, but a 19" wheel on a stock height gti will make it look like a wagon
if you are very adamant about getting his setup, it may be worth the trip to test fit first and save yourself the grief later.
Old 05-30-2010, 12:50 PM   #120
kidthunder
Formula 5000 Driver
kidthunder's Avatar
Drives: 07 BMP GTI
any one know where i can buy hub centric rings that arent plastic for lm reps (miro 279) 18x8
kidthunder is offline   Reply With Quote
Old 06-02-2010, 08:35 AM   #121
Cybe
GolfMK5 Graduate
Cybe's Avatar
Drives: 10GTI, 97JET
Bump, I shared this chart @ GolfMK6. Thanks, RRRabbit
Cybe is offline   Reply With Quote
Old 06-24-2010, 01:59 PM   #122
Mainline
ant
Mainline's Avatar
Drives: MKV Rabbit, DC2 Honda (actual)
thinking about picking up some RPF1s in 18x7.5, +48 trim. what size spacer should i get to bring them out closer to flush?
Mainline is offline   Reply With Quote
Old 06-29-2010, 09:22 PM   #123
vwarceo
vwarceo's Avatar
Drives: 2008 R32
Newer to this forum and am having fun learning about new things. Am looking for wheels on tirerack right now and these are what we like.
Looking at ASA AR9 wheels that are 19x 8.5 +45 with 225/35/R19. Any danger of rubbing with 5 ppl in the car?
Also bolt pattern is 5-112......will this fit alright.
Any thoughts on good winter/all weather tires are also welcome. Thanks.
vwarceo is offline   Reply With Quote
Old 08-05-2010, 09:47 AM   #124
jsdtdi
Autocross Newbie
Drives: 2.0 gt tdi
Sorry to bother anyone here just a quick question.
Found some Merc 17x8 alloys 5x112, tyres on there at the moment are 205's just wanted to ask what the ET boundaries for these wheels to fit a golf mk5 would be?
If the et is lower does that mean they will stick out?
Seller believes they are et 35 - hasn't checked though!
Much appreciated.
jsdtdi is offline   Reply With Quote
Old 08-11-2010, 06:33 PM   #125
BreezyGTI
Drives: '06 VW GTI
i am looking at some 18x8 et45 ASA AR1's and i'd like to have a little stretch. i have highsports i havent installed yet and was wondering if i'd rub with 215/35/18
'06 VW GTI - Racelands(Dont hate) | EuroSport Exhaust System | ...so far |
'88 BMW 325i Vert - | alpine white/cardinal | ireland engineering cat-back exhaust |
ireland engineering stage 3 race springs | smoked corners/sidemarkers | euro plate |
mb motoring rev 16x7 | zimmerman cross drilled slotted rotors |
Flickr | CarolinaEuros | CharlotteCarsandCoffee
my phone's cooler than yours b/c its got an apple on the back.
BreezyGTI is offline   Reply With Quote
Old 08-11-2010, 06:53 PM   #126
mobbin6
Drives: Gti
no you'll be okay. The only thing is that if you're gonna go with a 215/35, make sure you go LOW. Its a small tire, and if you're not low, the sidewall is gonna make your gap look huge and it won't look too great. If not a 215/35, a 215/40 would be perfect.
18x8 et 45 with a 215/40 tire. FK's all the way down in rear with everything still in. No helper springs in the front. 10-12 threads left. Hope this helps. Oh and front fenders are rolled.
mobbin6 is offline   Reply With Quote
Old 08-12-2010, 09:29 AM   #127
slideordie
Drives: GTI DSG
Looking at a set of 18x9 rear and 18x8 fronts ET35 with 215/40 tyres, my car is sitting at the top of the tyre all round, front arches will be rolled. Anyone with a similar setup that could fire up a pic so I can get an idea what they'll look like?
slideordie is offline   Reply With Quote
Old 08-30-2010, 08:53 PM   #128
silver_z33
Less mpg
Drives: 2013 GLI Autobahn w/Nav
Yo thanks for this sticky man just saved me putting up a thread lol
I just want one girl to trip in front of me so I can say bitches be tripping and have it be literal.
silver_z33 is offline   Reply With Quote
Old 09-02-2010, 06:29 PM   #129
BMPgtiMk5
Drives: BMP 07 Gti
I wanted to buy some audi a6 rims from a b5 to run for the winter on my mk5 gti. they are 16x7 et 45 can i use my stock bolts and no need for hubcentric rings correct? any help would be appreciated.
BMPgtiMk5 is offline   Reply With Quote
Old 09-06-2010, 09:55 PM   #130
Cbus mkv
Lowcally Famous
Cbus mkv's Avatar
Drives: 2008 GTI MKV
epic thread
Cbus mkv is offline   Reply With Quote
Old 09-15-2010, 08:35 PM   #131
sullwe
Oval Champion
sullwe's Avatar
Drives: '07 GTI
Hey guys quick question, if the offset gets lower does that make the wheel be more flush with the outside of the car? looking to get 17x8 tsw et 45 and probably some spacers.
'07 GTI - Neuspeed P-flo intake, APR Stg 1, 42DD bushings, Newsouth Coloumn Pod, H&R Sport Springs, Koni Yellows
sullwe is offline   Reply With Quote
Old 09-16-2010, 11:58 AM   #132
blkmaggtsp74
FIA GT Newbie
blkmaggtsp74's Avatar
Drives: Golf TSI GT sport -08
Yes, and i would say 5-8mm spacers in the back and 5mm in the front and maybe 215/45 if you´re a bit lowered.
blkmaggtsp74 is offline   Reply With Quote
