Parts4Euro
Old 05-25-2008, 09:27 PM   #1
gmc
FIA GT Newbie
gmc's Avatar
Drives: '05 MKV GTI
Send a message via MSN to gmc Send a message via Skype™ to gmc
Whiteline Front Anti-Lift/Caster Kit now in stock
As the photos show, some very nice bling to add to your undercarriage from Whiteline. We'll be fitting a set to the GC Corp GTI in the next couple of weeks.
Whiteline Anti-Lift/Caster Kit (Front) - VW Golf MKV/Jetta MKIV IK
Suits:
VW Golf MKV
VW Jetta MKV
VW Passat MKVI
The Whiteline Anti-Lift/Caster Kit is designed to increase the positive static caster setting by up to +0.5 degree of both front wheels, while at the same time modifying the front anti-dive and lift geometry. The low compliance bush also maintains higher dynamic positive caster resulting in improved front end grip and steering feedback.
Price: $220 inc GST
gmc is offline   Reply With Quote
Old 05-25-2008, 09:57 PM   #2
Hilton_K
Formula 5000 Driver
Hilton_K's Avatar
Drives: GTI 2007
Wheel alignment required once fitted or is it and D.I.Y mod?
'07 GTI
6MT[]Xenons[]Bluefin Stage 2+ []Neuspeed TAI[]E.I.P Short Shifter[]Defi Boost Gauge[]OSIR Pod[]Whiteline ALK[]H&R Sway Bars[]
GruppeM & Neuspeed Combined Intake[]Milltek Dump Pipe[]Hawk HP+ Pads[]Braided Lines[]AP600 Fluid[]Forge Catch Can[]APR HPFP[]
Mods Supplied By:
Rennenhaus, GMC Corp & ECS Tunning
Hilton_K is offline   Reply With Quote
Old 05-25-2008, 10:14 PM   #3
gmc
FIA GT Newbie
gmc's Avatar
Drives: '05 MKV GTI
It will require a wheel alignment as the caster angle changes. You'll need a press to take the stock bush off the control arm according to the instruction sheet.
Old 05-25-2008, 10:18 PM   #4
Hilton_K
Formula 5000 Driver
Hilton_K's Avatar
Drives: GTI 2007
Okies so that's a definate trip to a suspension place
'07 GTI
Mods Supplied By:
Old 05-27-2008, 04:13 AM   #5
Vagabond
Great Teutonic Invention
Vagabond's Avatar
Drives: 09 Sprint Blue S3 Sportback
Any disadvantages to the caster kit?
NVH or premature bearing or suspension wear?
Certainly sounds like a good and cost-effective mod.
2009 Sprint Blue Audi S3 Sportback - 18" BBS CH's
Originally Posted by Lima View Post
Yeah, there's a chance. There's also a chance you'll get a blow job from the tooth fairy as well.
Vagabond is offline   Reply With Quote
Old 05-27-2008, 09:45 AM   #6
gmc
FIA GT Newbie
gmc's Avatar
Drives: '05 MKV GTI
From our experiences with other vehicles using Whiteline's caster/anti-lift kits, these can only make things better. From studying the construction of the units, they look extremely study with OEM like construction. The bush itself has small voids cast into it so it will allow a limited amount of flex and compression which should keep things fairly compliant and quiet.
Better front end grip and steering feel is usually experienced from this type of modification. Once we've got them fitted, I'm sure that some of the guys will be keen to try them out during one of our regular GTGs.
Old 05-27-2008, 11:58 AM   #7
funky_chilli
Formula 5000 Champion
funky_chilli's Avatar
Drives: '08 GTI + '09 323i
excuse the noobness but what does a caster/anti-lift kit do?
what does it stop from lifting? :)
cheers,
wils
i finally got my GTI.....but i still kinda miss my little MINI
Originally Posted by James G View Post
Ok, i'm a wanker, i know
funky_chilli is offline   Reply With Quote
Old 05-27-2008, 11:17 PM   #8
Hilton_K
Formula 5000 Driver
Hilton_K's Avatar
Drives: GTI 2007
Stops the nose of the car from lifting during acceleration, leaving more weight over the front tires
Mate had his WRX fitted with a whiteline A.L.K and it made quite an improvement on take off and corner exit acceleration with the car being more stable and less likely to spin the front wheels.
'07 GTI
Mods Supplied By:
Old 05-28-2008, 01:11 AM   #9
Capercat
It's a chuck-about
Drives: A frog
Lift was massively reduced when I switched to coilovers.
I would imagine the ride would be a little harsher, but that's just my imagination.
Capercat is offline   Reply With Quote
Old 05-28-2008, 01:21 AM   #10
funky_chilli
thanks for the explanation
only experience i've ever had with an anti-lift kit was also a mate with a subaru and he told me what it did years ago but i couldn't remember! haha
i was watching gti's launching on youtube the other nite and was thinking that on hard acceleration that the front lifts a fair bit! now i know how to reduce that!
cheers,
wils
Old 08-27-2008, 10:47 AM   #11
Dave1078
Drives: MK6 GTI
Bump..
Anyone have a review for the anti-lift kit on their MKV? There's a thread going on in the suspension forum and I figured you guys might know best.
Dave1078 is offline   Reply With Quote
Old 08-28-2008, 05:16 AM   #12
Hilton_K
Formula 5000 Driver
Hilton_K's Avatar
Drives: GTI 2007
I have the kit installed. Got it done at the same time as my sway bars, this is what I wrote about them....
I have just recently installed H&R sway bars and the Whiteline Anti-Lift Kit (ALK) to my GTI. Still retaining the stock springs and shocks.
ALK: 7/10
Made a noticable change to the amount of weight transfer that the car has whilst accelerating hard, ie puching it in second gear or accelerating out of a low to mid speed corner. The nose of the car doesn't want to pick up at all, kit also adds 0.5 degrees of static caster to aid turn in.
For those with coilovers or shock/spring combo's this is probably not needed but to those like me who are keeping the stock shocks and springs I would recommend the A-LK
Sway Bars: 8.5/10
I went with the smaller H&R set. This is a great upgrade and a definate must have!! Car corners very flat and changes direction with very minimal body roll, great for throwing the car around in the corners. Only thing I was a little disappointed in was the turn in response. It didn't change as much as I was hoping but it is still a good improvement over stock, getting a larger rear bar would help this but would also bring on oversteer something I wasn't really after, more of a neutral car person when it comes to FWD's.
In the end I am happy with the results of these upgrades.
Thanks to GMC for the Anti-Lift Kit and great customer service.
'07 GTI
Mods Supplied By:
Old 03-10-2009, 03:52 AM   #13
POLARBEAR666
FIA GT Champion
POLARBEAR666's Avatar
Drives: Golf GT TSI
Do they need to remove the control arms to push the old OEM stuff off with a press? or is this mod a 1-2 hour job? on the car.
*Disclaimer: nothing I say should be relied upon // Click the links for pictures
Dynolicious 6.89 to 100kph 0.8g max 143kw// KW V1 Coilovers// Custom Intake// Deleted Muffler// Deka ETX18L battery 8.2kg 720CCA// Weight Reduction ~50kg
POLARBEAR666 is offline   Reply With Quote
Old 03-10-2009, 05:42 AM   #14
amrjon
FIA World Rally Car Champion
amrjon's Avatar
Drives: mkV gti R spec
Some more info from whiteline here.
amrjon is offline   Reply With Quote
Old 03-10-2009, 06:00 AM   #15
POLARBEAR666
FIA GT Champion
Drives: Golf GT TSI
Thanks for trying to help me. Already seen that. Unfortunately it gives no indication of how long it should take to fit it or what needs to be done to fit it.
I don't think I will bother getting this item if it is a 4 Hours of labor type thing. Which would add up to $300 plus at my suspension place!
Old 03-10-2009, 07:03 AM   #16
bj240z
Newbie
Drives: GTI Pirelli MKV
I recently had this done for me from the guys at BDA motorsport on the GC. The kit is great, and only takes about 1.5hrs to install. The harder side is the left side, as one of the bolts can't come out, without dropping the sub frame a little. And yeah, the arms come off so they can press out the bushes.
GTI Pirelli, APR, Tint, Rear Parking Sensors, Slotted Rotors, Hawk Ceramic Pads(Front Only), Whiteline Anti Lift Kit, Whiteline F/R 24mm Sway Bars, Front SS Braided Lines, Deleted all Stone Shields, Race Brake Fluid Done
bj240z is offline   Reply With Quote
Old 03-10-2009, 10:13 AM   #17
SevenW
Touring Car Champion
SevenW's Avatar
Drives: UG 5dr GTI
I have a WALK installed, pretty good...........GMC is great, top service.
Installation is about 1Hr, but you do need alignment done, so maybe buy this keep it until you get the suspension done too.
SevenW is offline   Reply With Quote
Old 03-10-2009, 06:52 PM   #18
DRMAT
Formula 3000 Champion
DRMAT's Avatar
Drives: Black Magic MkV Golf GTI DSG
Another MElb member has both Whiteline bars and the ALC fitted as well and didn't take to long to fit... ignoring that some of the 'left' parts were marked 'right' and vice versa. He loves it.
Mat
DRMAT is offline   Reply With Quote
Old 02-07-2010, 05:45 AM   #19
fuscobal
Drives: 2006 black pearl MK5 GTI
Send a message via Yahoo to fuscobal
Does one also need to change the front wishbone inner bushes once with the WALK ? (I've heard the whiteline affect the OEM front bushes in time )
http://www.jkm.org.uk/performance/tfsimisc.htm > powerflex inner bushes
2006 Black GTI|Milltek Non-Res Turbo-Back|BSH 27mm RSB+H&R 28mm FSB|BSH pendulum mount + custom side mounts|Evoms V-Flow|BSH pcv revamp|Sachs racing clutch|Forge SS+42DD/FFE bushings|Ohlins R&T|Peloquin LSD|K04 turbo|S3 injectors|Je pistons/IE rods/Calico bearings|Ap Racing Pro 5000 F + S3 R brakes + Pagid RSL1/Carbotech XP8 pads|THS FMIC|S3 camshafts|Autotech HPFP|235/40/18 FZ-201+TD 1.2|REVO Stage 3
fuscobal is online now   Reply With Quote
Old 02-07-2010, 06:15 AM   #20
Schnitzel Baby
Bright shirt, dull mind
Schnitzel Baby's Avatar
Drives: MK5 Golf GTi
I don't know if you have to, but it makes sense to do it at the same time. The inner bushes are cheap anyway and that way you have the same compliance on both ends of the wishbone.
I did the WALK install myself without a press by drilling a series of 8mm connecting holes out the OEM rubber bush, twisting the old centre out and using a hack saw to cut through the aluminium sleeve. It's not as brutal as it sounds and was actually pretty easy once I'd figured out how to do it. The Whiteline bush pushes in easily in by hand.
Schnitzel Baby is offline   Reply With Quote
Similar Threads
ABT or Vortex VW Stock Kit?? ZeroSlash Cosmetic Mods (interior+exterior bodykits, CF kits, etc..) 29 12-23-2009 10:00 PM
How To: Convert Mk5 Golf Front End to GTI, GT or Jetta goofer101 Cosmetic Mods (interior+exterior bodykits, CF kits, etc..) 13 10-09-2007 03:37 PM
Big Brake Kit with stock wheels??? Mr Baytchos Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 3 06-27-2007 06:43 PM
Pic Request: Votex Front with Stock Painted Sides CASHmoney Photo / Video / Media Gallery 11 09-14-2006 03:28 PM
Stock front lip MRSiGTi DIY + Maintenance + Tips/Tricks 4 07-04-2006 12:43 AM
