WhiteJames
Fun Nazi
- Sydney
- VW Golf GTI MKV
GTI –v- R32
Ride & Handling Review
Vehicle One
White James Golf GTI fitted with Koni FSD dampers, Eibach ProKit Springs, H&R adjustable anti-roll bars (26mm/22mm) with front set soft & rear on hard to dial out under-steer for near neutral handling, neuspeed torque arm insert 88 duro.
Lowering: Front 20mm; Rear 8mm.
Vehicle Two
Rennenhaus.com.au 3 door R32 equipped with haldex gen II controller, complete VF engine mounts to reduce under bonnet engine movements creating further rigidity, lightweight (18lbs) neuspeed wheels (18 x 8 x ET50), Modshack cold air intake (CAI), neuspeed torque arm inserts, Thunder Bunny neuspeed suspension kit comprising: Koni – Sport dampers, neuspeed sport springs, neuspeed rear adjustable tubular sway bar (25mm) set on hard, neuspeed heavy duty rear sway bars links (note that front neuspeed not fitted due to production delays) – probably a host more items that I forgot to take note of when the owner Ian was talking to me. Koni-Sport front set on ¾ hard and rear ½ hard. Haldex controller set on ‘sport’.
Lowering: Front @ 15mm; Rear @ 15mm (note R32 stock is -10mm lower than GTI).
Royal National Park between Sydney and Wollongong. Generally known as part of the Great Ocean Road. This route provides many different surface textures and generally makes mince meat out of vehicle that is not set up well for real world conditions. A race track type set up is not likely to do well on this stretch of bitumen.
Vehicle One
Vehicle Two
