WhiteJames
Fun Nazi
- Sydney
- VW Golf GTI MKV
Comparison: Small -v- Large sway bars / Coilovers -v- Strut Dampers
Comparison: Large v Small Sway Bars - Coilovers v Struts
Aim: Comparison of large v small anti-roll bars.
Coilovers v Strut - Spring upgrade
Roadways:
Roadways consist of coarse bitumen, uphill/downhill gradients, tight and flowing corners complete with flat and undulating surfaces and minor pot holes. Some sections of roadways change texture mid corner.
The idea is to use a roadway that replicates much of what every driver is likely to encounter in day to day driving conditions.
Some routes were driven 4 times over so as each driver experiences each of the four vehicles on exactly the same portion of roadway.
The driver swaps eliminates any subjective views and exposes each VW GTI to varying driving techniques.
Conditions were overcast – dry and damp roadways.
Items description:
(1) TEIN Euro Coilover + EDFC
TEIN Euro coilover suspension is equipped with EDFC (Electronic Damping Force Controller) which makes it possible for the driver to control the damping rate via remote control from inside the vehicle with cables leading through the vehicle (under carpet & rear seat) connected to miniature motors attached to the bottom of the coil over damper tube.
All the driver has to do is operate a number of buttons from a controller inside the vehicle to alter damping rate; rather than jack up car & fiddle with the settings as in the case of a conventional coil over systems. The damping force control function is able to be calibrated for either 16 levels or 32 levels.
The TEIN Euro EDFC really is the cream of the coilover crop in suspension upgrades. These items are similar to the Porsche PASM/Bilstein B16.
Price: approx $3800.
TEIN provide a 3-year/30,000km warranty on coil over and 1-year warranty for EDFC.
(2) Koni FSD - Strut damper
Shock absorber offers a superior road-holding without compromising comfort. The frequency selective damping valve (FSD) is patented by Koni which combines the benefits of firm and comfortable suspension in a single shock absorber. Firm for sporty driving on even road surfaces. Soft for uneven surfaces.
Damper is light in weight and cost efficient. Koni-FSD adjusts automatically to road conditions as well as driving style. All in a fraction of a second.
Warranty: ‘Limited Life Time’ which means that they are warranted for the entire duration that the original purchaser owns that particular vehicle regardless of mileage.
Cost: $1200.
(3) Eibach Prokit Progressive rate springs
The Eibach ProKit are springs suited to sports suspension that can be used in conjunction with both production shocks, the Eibach Pro Damper as well as with other types of aftermarket shocks such as Bilstein Sports, Koni Sport and Koni-FSD.
The springs are aimed at a sporty road performance without sacrificing any driving comfort. Vehicles such as the new Mitsubishi Lancer EVO-X and HSV GTS have Eibach springs as factory standard equipment.
Warranty: 1 million mile warranty.
Cost: $600.
(4) H&R anti-roll bars
H&R sway bars are made from the highest tensile strength available making them strong/durable and are 100% made in Germany to exacting standards. Each bar is cold-formed. The bars are heat treated, shot-peened and powder coated. The sway bars include bushing featuring a special Urethane/Teflon composite that eliminates the need for lubrication. No squeaking.
The front bars are set on ‘soft’ and rear set on ‘hard’ to dial out under steer for a near neutral biased chassis set-up.
Cost: $890 pair.
Roadways:
Items description:
Cost: $1200.
Cost: $600.
Cost: $890 pair.
