GTIzzle07
NY Dubz
- New YorKk.
- 2007 GTI
tools: t20 and t15 bit.
small screwdriver
unscrew the 2 hex screws with a t20 bit. there are two of them one on far left and on far right. Some GTIs have 4 of these. mine were t20 other people have t15 and t20
Remove the front grill piece.
Press clips inward and turn the center assembly a 1/4th turn counterclockwise.
TO Get The crome piece off you must use a small screw driver or similar tool to slightly open the two plasice peices holding the clips on the back of the symbol, there is like 8 of them.
SAnd with 400 grit sandpaper, be sure to scuff all inner surfaces and small spaces inside the symbol holder piece.
I used automotive paint, make sure it bonds to plastic.First coat.
Second coat
Letin the paint dry ! hah nfs carbon
Spray coat . Used spray paint, Krylon works well. I taped off all of the holes on the plastice piece so it would be easy to snap chrome symbol back in.
I let it dry for over 24 hours and put it all back together. ..
good luck keep dubbin
small screwdriver
Second coat
