![]() Support GolfMKV by clicking this link to do your tirerack shopping, THANKS!
Thread Tools |
#1 |
FIA World Rally Car Champion
![]() Drives: 07 GTI Manual Join Date: May 2007
Just spoke to "Mike" @ bilstein regarding Sport Shock/Strut vs pss10
I mentioned my application was 90% street and 10% auto x. He said that the pss10 at the hardest setting is softer than the Sport shock/strut (depending on which spring is matched) So for a daily driver the coils are best with occasional track usage. He also mentioned that for the pss10 kit they had to compromise and find a spring that could be a "do it all" regardless of the firmness setting so even at the 10 level (hardest) it was still streetable.
Whereas the shock spring combo is more versatile where a driver can match it to a softer spring like Drivergear or eibach sport for daily usage, or a race spring and go balls out. he did note that he only recommends 1" drop springs regardless of spring rate for the bilstein sport shock/strut kit. |
#2 |
don't be an asshat.
![]() Drives: 06 GTI, 08 GTI, 96 2.0 racecar Join Date: Apr 2006
did he happen to mention any spring rate values?
#3 |
i can't say for the pss10
but when i spoke with the r&d tech about the pss9 he told me the springs are progressive, but in the meat of the working range they are 350 front, 290 rear |
#4 | |
i felt the same thing when i rode in a bilstein sport shock equipped mkv gti i immediately thought WOW, this is stiffer than my car (when i had the pss9) |
#5 |
don't be an asshat.
thanks. finding spring rate info is a PITA, let alone verifying it.
#6 |
yeah, those rates are really low considering its progressive, and the car is over 3100 lbs
my last car that weighed 500 lbs less, had stiffer rates than those
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| eibach with bilstein sport on GTI/ rabbit 4 doors | ferrarista | Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack | 5 | 12-11-2008 04:16 PM |
| S3 + Bilstein PSS10 + H&R Anti Roll Kit inst | mikenbn | Australia | 25 | 09-16-2007 06:41 AM |
| Installed the H&R sport with bilstein sport too! | VWgirl | Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack | 7 | 04-29-2007 10:51 AM |
| H&R Sport / Bilstein Sport combo | MikeW | Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack | 4 | 12-08-2006 11:02 PM |
| Bilstein sport shocks and struts with Neuspeed sport springs | KevinFastMkV | Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack | 4 | 03-20-2006 07:01 PM |
