Old 02-17-2008, 04:11 AM   #1
JudgementDEY
Euro tuned Freak
Drives: 2007 MKV GTI Black Magic
Kumho tires Suck!!
I have KUmho escta SPT's for 5,000miles and they give me no more traction anymore . I Spin my Tires all the way up until 3rd Gear!!!! If your running Stage 2 these tires are horrible no traction!!!!
Neuspeed P-FLow,NEUSPEED Hi-Flow Turbo Discharge, Hi-Flo Intercooler Pipe,ATP Downpipe,APR Stage 2,Boost gauge,H&R Sport springs,smoked side markers.
FAST IS MY CO-PILOT
JudgementDEY is offline   Reply With Quote
Old 02-17-2008, 04:26 AM   #2
DarkstaR
dope freshhhhhhhhhhh
DarkstaR's Avatar
Drives: 2007 VW GTI
the Ecsta series isn't great for traction no doubt.
although, they are good for tread wear.
I have the Ecsta ASX's and I'm about to hit 30k (the tires, not the car) and the tires are doing okay (although they are almost completely bald).
Derek
DarkstaR is offline   Reply With Quote
Old 02-17-2008, 04:36 AM   #3
SRTthis
NJ 2 FL
Drives: 2007 United Gray GTI
Send a message via AIM to SRTthis
i have those same tires im on 7k now and they are still like brand new. is your aligment on? and do you spin tires alot or drive very aggresivly?
Performance Mods: Revo Stage 1. 2.5" custom DP back straight pipe. Neuspeed P-Flo intake. KW Variant 3 Coilovers, VF Motor Mounts, and the cars on a diet
SRTthis is offline   Reply With Quote
Old 02-17-2008, 04:40 AM   #4
DarkstaR
DarkstaR's Avatar
Drives: 2007 VW GTI
oh yeah I forget to add that if you want to avoid wheel spin/torque steer then you should work on throttle control.
Derek
Old 02-17-2008, 10:23 AM   #5
NewaveRide
LOLOMGWTFEUROVERATED
NewaveRide's Avatar
Drives: Thumper
Send a message via AIM to NewaveRide
and look into get a dogbone insert. it will help with the wheel spin some
NewaveRide is offline   Reply With Quote
Old 02-17-2008, 10:44 AM   #6
ShadowGLI
Sandy Vagina Rinser Outer
ShadowGLI's Avatar
Drives: 2006 VW GLI w/ DSG
Send a message via AIM to ShadowGLI
Kuhmo is designed to be a CHEAP and DURABLE tire for low profile use.. if you want something sticky get ready to pay $200+ each tire and replace them each season...
And as said before, did you lower your car without an allignment, you can kill wheels in like 10,000 miles of less if not...
Before you PM me about how my COUSINS car is so low on racelands click HERE
ShadowGLI is offline   Reply With Quote
Old 02-17-2008, 01:44 PM   #7
labelskate
Deutschland MKV
labelskate's Avatar
Drives: 2008 GTI
I heard you don't have to align the tires in the GTI due to type of power steering it has... from a VERY credible source too.
MKV GTI
BSHmotorsports
labelskate is offline   Reply With Quote
Old 02-17-2008, 01:48 PM   #8
DarkstaR
DarkstaR's Avatar
Drives: 2007 VW GTI
whatever the credible source was, I would still get an alignment regardless.
Derek
Old 02-17-2008, 04:06 PM   #9
absoluteczech
GolfMKV ADMlN
absoluteczech's Avatar
Drives: 2010 GTI - Candy White - 2DR
qft
op get an alignment after lowering
Originally Posted by MHS216 View Post
If learning the lug pattern is going to cause a "headache", dealing with VWs is gonna give him brain tumors.
SO*CAL GolfMKV crew #001 <~j4x0r made me put this
absoluteczech is offline   Reply With Quote
Old 02-17-2008, 07:54 PM   #10
ShadowGLI
ShadowGLI's Avatar
My car rode like hell over 50mph and I went through a set of tires in 8 months, get an allignment..
Old 02-17-2008, 08:07 PM   #11
JhnR
JhnR's Avatar
Drives: BM4D
Send a message via AIM to JhnR
$109 -RT615.
JhnR is offline   Reply With Quote
Old 02-17-2008, 08:20 PM   #12
mvhswr85ua
Touring Car Champion
mvhswr85ua's Avatar
Drives: 2004 Audi S4
I bought some 225/40/18 General Exclaims for autocross, they sure do stick and don't cost 200+ a tire. If you want something that will grip, I'd go with Yokohoma S.Drives.
mvhswr85ua is offline   Reply With Quote
Old 02-17-2008, 08:56 PM   #13
07GTI-2.0T
FIA GT Champion
07GTI-2.0T's Avatar
Drives: 07' CW GTI 6sp manual
SPT are actually class leaders in traction and as you can see below fair better than well against competitors:
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=97
http://www.tirerack.com/tires/tests/...lay.jsp?ttid=4
look at the "test result charts" and you will see they run circles around the General tires in lateral G's and outperform the Yok S. Drives as well.
your problem is you bought a budget ultra high performance tire expecting max or extreme peformance tire peformance. Hell there is NO tire a chipped 2.0T wont spin. I spun max performance contisport 2's, brigdestone RE050's and the SPT's too ( I bought em because I will sacrafice a little performance for twice the intervals between tire changes).
what were those 1rst kumho street tires that came out years ago before the MX that everybody had because they were cheap? those DID suck but kumho has come a long way in street tires starting with the MX to present (always made decent track tires).
07GTI-2.0T is offline   Reply With Quote
Old 02-18-2008, 12:27 AM   #14
veedubin
Cone chaser
veedubin's Avatar
Drives: United Grey GTI
Originally Posted by jhnr View Post
$109 -RT615.
Agree here. But you cant say all kuhmos suck. Every tire brand makes cheap crap tires and higher end performance tires. For example the kuhmo mx's are probably alot better then the tires you currently have.
United Grey GTI, APR STAGE2, intake, milltek tbe, Koni coils, filk ftd/ Falken Azenis. Dan GSR- Custom 28.5mm Rear Swaybar.
http://autox4u.com/
http://dangsr.com/
http://youtube.com/watch?v=d_xdgPbmBks
19-NO.. Giants Superbowl XLII Champions!!!!!!
veedubin is offline   Reply With Quote
Old 02-18-2008, 12:31 AM   #15
JudgementDEY
Euro tuned Freak
$109 -RT615.
Im going with that setup
FAST IS MY CO-PILOT
Old 02-18-2008, 12:32 AM   #16
JudgementDEY
Euro tuned Freak
It is alligned ! These tires just wont grip anymore !!
FAST IS MY CO-PILOT
Old 02-18-2008, 12:38 AM   #17
JudgementDEY
Euro tuned Freak
I might go with these what do you guys think? http://www.tirerack.com/tires/tires....1=yes&place=49
FAST IS MY CO-PILOT
Old 02-18-2008, 12:46 AM   #18
RedRabidRabbit
I want FREE HAM!!
RedRabidRabbit's Avatar
Drives: 2011 GTI incoming
No street tire is going to give you good straight line traction.
RedRabidRabbit is offline   Reply With Quote
Old 02-18-2008, 01:09 AM   #19
muskaroxs
muskaroxs's Avatar
Drives: GTI Tornado Red.DSG
I got stuck in a snow storm with my Kumho MX'S and they kept me alive! lol
I also have the general exaclaims and they seem like a quality tire for the price.
muskaroxs is offline   Reply With Quote
Old 02-22-2008, 12:37 AM   #20
ChadNH
FIA World Rally Car Champion
ChadNH's Avatar
Drives: '08 GTI, '95 Miata M
I was thinking about gettting the Kuhmo MX's just because of the price...how did they work out for you?
ChadNH is offline   Reply With Quote
Old 02-22-2008, 01:08 AM   #21
absoluteczech
GolfMKV ADMlN
mx's suck with road noise, oh man i had them on my 18" rs6 wheels and i would never get them again, the loudest tire ive ever driven on
Old 02-22-2008, 12:11 PM   #22
EL PAALO
FWD FTL
EL PAALO's Avatar
Drives: '07 GTI
Send a message via MSN to EL PAALO
the MX, v700, and v710 beg to differ. Most of Kumho's tires are ecsta and they make some very sticky ones.
wheelspecs.com
sasca.org
spokes.org
EL PAALO is offline   Reply With Quote
Similar Threads
For Sale: 18" Merch Rims with tires $2000 CrazyRabbit Classifieds - Buy, Sell and Trade 0 01-30-2008 10:54 PM
18" RS6 Reps w/ Kumho A/S tires for sale in Philly area Skim Diesel Wheels + Tires for sale/trade/requests 4 12-29-2007 11:27 PM
One thing to watch with Winter tires! GTI lover all over again Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 6 11-03-2006 11:31 PM
FS: 16" steel vw rims w/ Kumho 716 all season tires dpvw22 Classifieds - Buy, Sell and Trade 6 10-23-2006 07:27 AM
17" OEM Summer tires DubtecV2 Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 12 05-26-2006 12:09 AM
