Old 01-24-2008, 07:44 AM   #1
mikegally
mikegally's Avatar
Drives: 1.9 tdi se
reprogramming spare key / fob.
My 2005 golf came with only 1 key when i bought it, I have now bought a second key (exact same part number as original) from ebay and had it cut to fit my locks......spent £17 so far.
I now have 2 questions-
1. Can I go to Skoda or Seat to have it reprogrammed to my cars immobiliser as i assume they will be cheaper than vw or must i go to vw ?
2. What is the procedure to 'sync' the new fob to my central locking, I ask this as I understand there is a DIY method involving putting a key in ignition and pressing buttons on the remote etc but i've not seen a guide specific to the mk5 golf ?
any help appreciated.
Mike
mikegally is offline   Reply With Quote
Old 01-25-2008, 06:12 PM   #2
mikegally
mikegally's Avatar
Drives: 1.9 tdi se
I kept searching the web and found this......good job I did coz no-one on this site new the answer -
Hi all,
There are rumors flying that programming new remote key fobs to a Volkswagen is very easy. In order to correct any misinformation or misunderstandings related to this topic, I am writing this post to explain the details of the whole key matching process.
Quick Overview of a Volkswagen Key
A complete Volkswagen remote key fob consists of 2 parts: 1) the transmitter for radio remote control central locking system, and 2) main key with variable code transponder. If you lose either of these 2 parts you will not be able to start your car. But this will not happen because these 2 parts are tightly attached and it is not easy to separate them. The part numbers of these 2 parts for my Golf MK5 are shown below:
1K0 959 753 G - The transmitter (the remote)
1T0 837 246 INB - Main key with variable code transponder
Main key is on the left, the transmitter is on the right. Picture is from http://www.riskin.org/vwkey/.
Details
So how to program a new key to your car? Firstly, you will need to make sure that you get the right remote. There are literally hundreds of frequencies for the remotes, and it has to be the exact one for the central locking controller to pick it up. You can easily verify this by checking the part number. The part number of all the remotes for Volkswagen Golf MK5 starts with HLO 1K0 959 753 and has a suffix letter at the end. The suffix represents the model and the frequency of the receiver/controller being used on your car. For example, the part number of my remote is HLO 1K0 959 753 G. The suffix G represents a specific model of the controller on my car with the frequency of 434MHz. The following is a list of part numbers of the remotes for Golf MK5 I observed so far:
HLO 1K0 959 753 A - 434MHz for mobel PR-5D1
HLO 1K0 959 753 B - 315MHz for model "J..": PR-5D3
HLO 1K0 959 753 C - 315MHz for model "ROK": 5D5
HLO 1K0 959 753 D - 315MHz
HLO 1K0 959 753 G - 434MHz
Please be reminded that the above part numbers may not be suitable for your car. Please check with your dealer and don't buy the wrong remote.
Secondly, you need to find a locksmith who can cut the blade of a Volkwagen key. It shouldn't be too difficult to find one locally. Bring both of your keys (the existing and the blank key) to your locksmith and they will be able to replicate the key for you.
Finally, you will need to programme the new key to your car. There are 2 parts to programme the remote.
One for the doors (such that you can open/close doors and set/unset alarm using the remote)
One for the car immobilizer (such that you can start your car)
Part 1 is very simple. The following are the procedures:
Place your first key into the ignition and turn to the second notch (do not start the car)
Now close the door and place your second key into the handle lock
Turn the key to the lock position and let it spring back to the central position.
Hold down the Lock button on your new remote, you may hear a bleep from the car
Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
Close the door
Your remote should now be coded
Please be reminded that this procedure WILL NOT add your key to the immobilizer. Even you have completed part 1 and have the blade cut, you are still not able to start your car. This procedure will only code your key to connect to the controller so that you can open/close doors and set/unset alarm. However, this procedure can be used to re-activate an existing key that's lost its memory from a flat battery.
Part 2 is the MOST difficult part. You will need the following to complete part 2:
Volkswagen VAS 1551/5051/5052 or equivalent diagnostic equipment, OR
A Windows-based computer with VAG-COM and the correct interface for your car, AND
Secret Key Code (SKC)
Secret Key Code (SKC) can only be obtained from an official dealership. There are 2 formats of SKC from VW. Prior to 2002, some vehicles were delivered with a scratch-off panel on a plastic tag. A 4-digit SKC was printed on that panel. Starting in 2002, dealerships implemented the WIN2 system to provide SKC's to their technicians and customers. As of 11 Mar. 2002, VW and Audi are providing 7-digit Secret Key Codes in place of the earlier 4-digit SKC's. Keys must be coded using the new 7-digit SKC (secret key code) method unless the owner still has the correct 4-digit code. 7-digital SKC is generated based on the 14-digital immobilizer ID with your 17-digit VIN. Once the 7-digit code has been generated, the 7-digit SKC, the date on which the code was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code must be entered to the VAS 1551/5051/5052 or VAG-COM in order to add new keys to the immobilizer.
Recently, VW/Audi dealerships have switched to the new GeKo system, whereby their factory scan tools dial up the factory while connected to a car. Under this system, the technician no longer sees the SKC at all and you will need to bring your vehicle into the dealer to have immobilizer work performed. Note: GeKo connectivity requires VAS 5052 and broadband connection.
Conclusion
If you lose your key, you don't have much choice. Firstly, you need to get a blank new key. You can simply find one on eBay. But make sure that you get the right remote for your controller. If you still have the 4-digit SKC, then you will be able to add new key yourself using VAG-COM. Otherwise, you will need to take your car back to the dealer and have them do it for you. If you are lazy (like me), just request a new key from your dealer and they will order the key and program it to your car for you. But it will be very expensive.
References and Acknowledgement
Synchronise a new remote keyfobs: http://www.uk-mkivs.net/forums/451448/ShowPost.aspx
Ross-Tech VAG-COM FAQ: http://www.ross-tech.com/vag-com/faq_4.html#skc
Key Matching Process: http://www.steveslockshop.com/VW-hi-sec.htm
Volkswagen Key Disassembly: http://www.riskin.org/vwkey/
Mingfinity: he is so brave to disassemble his key and check the part number and the frequency of his remote
golfer: for verifying the part number and the frequency of a specific remote
Aric (uk-mkivs.net): for verifying some of the part numbers and the models of several controllers/receivers
ETKA
Official Volkswagen Service Manual
I hope this helps. If you find any incorrect information in this post, please feel free to correct me. Thanks.
Old 04-21-2011, 09:10 PM   #3
mraidan
Newbie
Drives: GOLF TDI 2.0 DSG
New key doesn't work
Hi everyone
I recently ordered a new key and transmitter (the type that click together) through vw parts. To do this the guy from parts said "its easiest if you just get your service manual out of the glove box so he can use the VIN to order the right ones.
When the key and transmitter arrived i took them next door to VW service to get them coded to the car. They ask me where I got the key from because its the wrong one. The key was cut correctly but is the wrong type. Apparently it should have a W stamped on the shank, so im guessing the someone somewhere screwed up with the transponder part in the key, very annoying. So i am yet to take the key back,and i've noticed since they tried to code the new key the word "SAFE" is constantly on the display.
I am assuming the transmitter part should be ok because both part numbers of the old and new one is HLO 1K0 959 753 G. Having said that i havn't been able to sync it to the car using the meathod at
http://uk-mkivs.net/forums/p/60202/451448.aspx#451448
Anyone ever had this sort of problem? Anyone have advice?
Thanks
mraidan is offline   Reply With Quote
Old 10-29-2011, 03:32 PM   #4
faraz619
Badman
Drives: Golf MkV
I tried that method ^ aswell didnt work for me any ideas?
faraz619 is offline   Reply With Quote
Similar Threads
key fob not working? SSS_Hoon Australia 12 06-01-2009 09:03 AM
.:R badge key fob mod **PIC** Fast.:R R32 Forum - General Discussions 47 05-29-2008 11:41 PM
VAG-COM Key Fob Window Control tranceporter Photo / Video / Media Gallery 11 12-24-2007 03:50 PM
anyone bought the osir key fob covers? they dun work foxyboy Cosmetic Mods (interior+exterior bodykits, CF kits, etc..) 11 01-20-2007 09:45 PM
Replacement key fob housing maxbrooker GTI / Rabbit / Golf MkV General Discussions 6 08-16-2006 09:48 PM
