#1 |
Autocross Newbie
![]() Drives: '08 CW GTI Join Date: Nov 2007
Neuspeed intake installation questions
Just got and installed my Neuspeed p-flo intake last night. I have several questions about the intake:
1) When I removed the factory turbo intake hose from the turbo, a rubber seal was left on the turbo inlet. I tried to stuff the neuspeed silicone hose over it, but it didn't want to fit. So I removed the rubber seal and assumed it was part of the factory intake hose. By fitting just the silicone hose over the turbo inlet, the fit was perfect. However, it just doesn't seem like it can withstand all the heat, is it made to do this, or was I supposed to use the factory rubber seal? 2) Although the intake is mounted by the silicone hose and the cylinder head, my intake wiggles slightly, is this normal? Tightening the 2 clamps on the silicone hose was hard due to limited space, so I am not sure if I tightened the clamps enough. When I try to pull the intake out, its impossible, so I do not know if this slight wiggle is normal. I'm just paranoid that one day while driving, the intake tube will disconnect from the silicone hose, leaving the turbo inlet open to sucking in debris. When I started the car, I noticed that there isn't the usual sound of more air being sucked into the filter, like on previous intakes I've installed. I'm not sure if this means there's air leaking somewhere, esp. where the silicone hose clamp rings are. I'm not getting any MAF errors or CELs. I know the best way to test my install is to do a test drive and try rev'ving the engine, but I finished the install late last night, and I wanted to get some input before I risk any damage. Thanks guys! |
#2 |
Behind the iron sights
![]() Drives: With wax Join Date: Dec 2007
1) Yes you were supposed to remove the rubber piece that is sitting around the inlet to the turbo. You are supposed to use the silicone hose that came in the box with your other stuff. One side is smaller than the other, the smaller end goes on the turbo. The hose clamps around the silicone hose should be tight, use a socket wrench.
#3 |
Call it how i see it
![]() Drives: MK4 Tornado Red .:R32 Join Date: Nov 2007
yes the wiggle is normal, its the hose flexing. souds like you got it in correctly
#4 |
Formula 5000 Champion
The wiggle is what keeps it from shaking itself to death. :)
MKVI GLI, MKVI R
#5 |
08 GTI mkV Midnight Black
![]() Drives: 08' GTI mkV Black Magic Join Date: Oct 2007
yes.. it will wiggle very slightly.. and you need to take out that stock seal to get the nuespeed hose over it.. sounds like your fine.. enjoy the sound
08 GTI mkV Black Magic |
#6 |
Rally Car Newbie
I was wondering the same thing at first but figured it was just part of the stock intake hose. but be assured it's the correct way(the way you did it).
And yes it is supposed to wiggle a bit, not too much.. but enough. ENJOY! |
#7 |
Autocross Newbie
holy crap you guys were right. It sounds awesome!!!!
I took a spin around earlier tonight...it sounds like I have a BOV when I really don't. ![]() It has that pssssh sound everytime I upshift (6 speed) or left off the gas. I thought it was only on upshifts. Oh well, im not complaining heheehe |
#8 |
F**K YOU CAM FOLLOWERS
![]() Drives: 2008 BMP GTI Manual Join Date: Nov 2006
awesome right, i put mine in sunday and love it. love the sound of the wastegate.
Street Stars
Last edited by tranceporter; 01-09-2008 at 10:11 PM. Reason: i need hooked on phonix |
#10 | |
MKVI GLI, MKVI R
#11 |
I thought the dv was full recirc. I have the forge vacuum powered without the spacer.
Street Stars
#12 |
Autocross Newbie
the best part is that its not overly loud. If I turn up my radio just a few notches, I can't hear the pssssh sound anymore. However, when I roll into a quiet neighborhood, under a bridge, or go inside a covered parking lot, its definitely loud enough for me. Not really sure why a forge spacer is needed...but my .02
#13 |
Anti-spin doctor
![]() Drives: 07 CW GTI MT6 Pkg 1 Join Date: Apr 2007
wiggle wiggle
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Neuspeed Intake Question... | Ballinfrogs | Engine / Drivetrain / Exhaust | 8 | 07-27-2008 11:56 PM |
| >> Redline Motorworks - Neuspeed Performance Parts | RedlineMotorworks | SPONSORS Classifieds Area | 18 | 03-28-2008 01:23 PM |
| neuspeed p-flo intake | my07blkgti | Engine / Drivetrain / Exhaust | 25 | 12-02-2006 08:13 PM |
| neuspeed intake | gtirevo33 | Engine / Drivetrain / Exhaust | 3 | 12-02-2006 09:21 AM |
| Neuspeed air intake | Icranon | Engine / Drivetrain / Exhaust | 16 | 07-24-2006 08:19 AM |
