Old 12-27-2007, 04:56 PM   #1
mel22b
Oval Newbie
mel22b's Avatar
Drives: 08 GTI 4 Dr DSG
Wilwood Brake Kit?
I was looking at this kit and wondering if anyone had any experience with it.
Thanks in advance.
APR 1 - STOCK Filter - OZ Ultraleggera - Eibach Prokit Springs - Hoen Xenon Matching Fogs - Smoke Sidemarkers - GPS
mel22b is offline   Reply With Quote
Old 12-27-2007, 05:09 PM   #2
absoluteczech
GolfMKV ADMlN
absoluteczech's Avatar
Drives: 2010 GTI - Candy White - 2DR
heard there pretty much pointless, from what i understood they were small, better off getting good pads and brake fluid, or spend a bit more and get stoptechs :D
Originally Posted by MHS216 View Post
If learning the lug pattern is going to cause a "headache", dealing with VWs is gonna give him brain tumors.
SO*CAL GolfMKV crew #001 <~j4x0r made me put this
absoluteczech is offline   Reply With Quote
Old 12-27-2007, 05:46 PM   #3
ShadowGLI
Sandy Vagina Rinser Outer
ShadowGLI's Avatar
Drives: 2006 VW GLI w/ DSG
Send a message via AIM to ShadowGLI
The only tricky part of stoptech's i've seen is that they have open piston design so you can't use them in the winter.. I don't know if they have since sealed up the pistons though for the newer cars.. Just something to consider but StopTech's are the bomb
Before you PM me about how my COUSINS car is so low on racelands click HERE
ShadowGLI is offline   Reply With Quote
Old 12-28-2007, 02:43 PM   #4
mel22b
Oval Newbie
mel22b's Avatar
I am just a bit confused. They are pointless because they are small? Small rotors?
Old 12-28-2007, 03:31 PM   #5
ShadowGLI
ShadowGLI's Avatar
Our brakes are VERY effective for a stock brake kit.. they just need better pads.. but they are already very large and you're buying calipers/rotors that are marginally better. (see not worth the $$) but if you go Wilwood, they are much better (larger/stronger) calipers and really good material as well.. basically you're better off getting good rotors, good pads and good fluid with stock calipers and stock sized rotors.. less $ and equal performance basically.
Old 12-28-2007, 04:19 PM   #6
sonomamkvdsg
7 time F1 Champ
sonomamkvdsg's Avatar
Drives: 06 Tornado Red MKV DSG
You ment if you buy Stoptech not Wilwood right?
I dig chicks whose panties match my car. TR-208
H8MINIS
the twin clutch king
sonomamkvdsg is offline   Reply With Quote
Old 12-29-2007, 11:06 AM   #7
ShadowGLI
ShadowGLI's Avatar
Nope, if you buy the Wilwoods in the first post, they are marginally better than better pads/rotors/fluid on OEM calipers/size.
STOPTECH however is a real big brake kit (Like Brembo etc)
Old 12-29-2007, 11:07 AM   #8
ShadowGLI
ShadowGLI's Avatar
Some more brake info for ya
They are classified by size sorted in an ascending order. All brakes pertain to the MK5 Platform.
Audi
A3 (2004+) | S3 (2006+) | TT (2006+)
VW
Golf (2004+) | Golf Plus (2004+) | GTI (2004+) | R32 (2005+) / Jetta (2004+) | EOS | Rabbit
Seat
Leon (2004+) | Toledo (2004+)
MkV brake combos for production vehicles (including most European models):
Audi S3 | Audi TT (3.2l) | VW R32
The Front brakes are 345mm x 30mm (13.38" x 1.18") Vented Rotors w/1 piston calipers
The Rear brakes are 310mm x 22mm (12.2" x .86") Vented Rotors
Part numbers: Disc: 1K0 615 301M | Carriers: 1K0 615 125 or 1K0 615 125-D | Calipers: 1K0 615 123 or 1K0 615 124 (Euro ETKA)
Audi A3 (2.0l TFSI) | Audi TT (2.0l TFSI) | VW Golf GT/I (2.0l TFSI | 2.0l TDI) | VW Jetta GLI/SE/Sport (2.0l TFSI | 2.0l TDI) | Seat Leon FR (2.0l TFSI | 2.0l TDI)
The Front brakes are 312mm x 25mm (12.3" x .98") Vented Rotors w/1 piston calipers
The Rear brakes are 286mm x 12mm (11.3" x .47") Solid Rotor
Part numbers: Disc: 1K0 615 301AA | Carriers: 1K0 615 125-C | Calipers: 1K0 615 123-B or 1K0 615 124-C
(Euro ETKA)
VW Jetta (S | 2.5l | TDI) | VW Rabbit (2.5l | TDI)
The Front brakes are 288mm x 25mm (11.3" x .98") Vented Rotors w/1 piston calipers
The Rear brakes are 260mm x 12mm (10.2" x .47") Solid Rotor
Audi A3 fwd/awd
Audi A3 fwd
The Front brakes are 280mm x 22mm (11.0" x .86") Vented Rotors w/1 piston calipers
The Rear brakes are 255mm x 10mm (10.0" x .39") Solid Rotor
Engine Configurations: (for reference. Not all are available on each vehicle)
Diesel
2.0l SDI 75hp
1.9l TDI 90hp
1.9l TDI 100hp (N/A model)
1.9l TDI 105hp
2.0l TDI 140hp
2.0l TDI 170hp
Gasoline/Petrol
1.4l 80hp
1.6l 102hp
1.6l FSI 115hp
1.4l TSI 140hp (Turbo / Supercharged FSI)
2.0l FSI 150hp
2.5l 150hp (N/A model)
1.4l TSI 170hp (Turbo / Supercharged FSI)
2.0l FSI 170hp
2.0l TFSI 200hp
3.2l FSI 250hp
FRONT BRAKE UPGRADES
Low budget Upgrades (replacement with same size)
Cross Drilled Rotors
Brembo
Slotted Rotors
Brembo
Cross Drilled and Slotted Rotors
TBD
12.6" (322mm x 32mm) Front Brake Upgrades
Movit 4 piston caliper Big Brake upgrade $
Comes with: 2 piece Rotors with cast holes and ventilation slots, aluminum hats, 4 piston calipers, brake pads, brackets, steel braided brake lines and bolts to mount the kit. The only thing that's not included is brake fluid. Black or Red calipers standard, other colors: $299 extra
Requires: unknown
Purchase from: Serious Euro Tuning | Movit
12.9" (328mm x 28mm) Front Brake Upgrades
Brembo GT Big Brake upgrade $2595+
Comes with: 2 Piece 328x28mm Slotted and Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Requires: 17"+ wheels
Purchase from: Brembo
Stoptech 328x28mm Big Brake upgrade $1895+
Comes with: 2 Piece Floating Directional 328x28mm AeroRotors (comes drilled or slotted and/or zinc coated, 4 Piston ST-40 Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Purchase from: Stoptech
Stasis Monobloc4 Big Brake upgrade $
Comes with:ALCON 4 Piston Monobloc Calipers, ALCON 328mm x 28mm(14") Floating Rotors, STaSIS Caliper Mounting Bracket & Hardware, Goodridge Stainless Steel Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Purchase from: Stasis Engineering
13.0" (330mm x 28mm) Front Brake Upgrades
AP Racing 6 piston Caliper Big Brake upgrade $
Comes with: 2 Piece 330x28mm Slotted Vaned Rotors, 6 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Requires: 18"+ wheels
Purchase from: AP Racing
AP Racing 4 piston Caliper Big Brake upgrade $
Comes with: 2 Piece 330x28mm Slotted Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Brembo GT Big Brake upgrade $1895+
Comes with: 1 Piece 330x28mm Slotted or Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Eurospec Sport Big Brake upgrade $
Comes with:Eurospec 4-piston calipers, adapter brackets, pads, Goodridge stainless steel brake lines, and all mounting hardware
Purchase from: Eurospec
RPI Equipped Big Brake upgrade $1895+
Comes with: 2 Piece 330x30mm Slotted and Drilled Vaned Rotors, 4 Piston Wilwood Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
Purchase from: RPI Equipped
13.5" (342mm x 34mm) Front Brake Upgrades
Requires: unknown
Old 12-29-2007, 11:07 AM   #9
ShadowGLI
ShadowGLI's Avatar
Movit 6 piston caliper Big Brake upgrade $
Comes with: 2 piece Rotors with cast holes and ventilation slots, aluminum hats, 6 piston calipers, brake pads, brackets, steel braided brake lines and bolts to mount the kit. The only thing that's not included is brake fluid. Black or Red calipers standard, other colors: $299 extra
Requires: unknown
13.6" (345mm x 30mm) OEM Front Brake Upgrades
Audi S3/TT 3.2l/VW R32 Brake upgrade $1295+
Comes with: 345mm x 30mm Vaned w/isolated hat Rotors, 1 piston Calipers, caliper carriers, dust shields, pads and brake lines
Purchase from: Autotech | VW Dealer
13.9" (352mm x 32mm) Front Brake Upgrades
MKV Jetta/Golf/EOS and Audi A3/S3 Brake upgrade $1295+
Comes with: 352mm x 32mm Vaned directional vaned rotor rings w/aluminum rotor hats, 6 piston Porsche Cayenne calipers w/ a new bracket-less caliper mounting system, Hawk HPS pads and brake lines
Requires: 18"+ wheels (OEM Wheels require 3mm spacer)
Purchase from: ECS Tuning
14.0" (355mm x 282mm) Front Brake Upgrades
Stasis 4 piston caliper Big Brake upgrade $
Comes with:ALCON 4 Piston Monobloc Calipers, ALCON 355mm x 28mm(14") Floating Rotors, STaSIS Caliper Mounting Bracket & Hardware, Goodridge Stainless Steel Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Requires: unknown
Comes with: 2 Piece 355x28mm Slotted or Drilled Vaned Rotors, 4 Piston Calipers, Caliper Mounting Brackets, Stainless Steel Brake Lines (Front Only), and Street Performance Pads (Front Only)
14.3" (362mm x 32mm) Front Brake Upgrades
Autotech/AP Racing 362mm Big Brake Kit (362mm x 32mm) $2995+
Comes with:6 piston calipers, 362mm x 32mm directional vaned rotors, lightweight 7075 aluminum rotor hats, caliper brackets, pads and brake lines
Requires: 18"+ wheels and Installation (spacers may be required depending on wheel offset)
Purchase from: Autotech | AP Racing
14.5" (370mm x 28mm) Front Brake Upgrades
Comes with:ALCON 4 Piston Calipers, ALCON 370mm x 28mm (14.5") Floating Rotors, STaSIS Caliper Mounting, Bracket & Hardware, Goodridge Stainless Steel, Braided Lines, Motul brake fluid, SBS Hi Performance Brake Pads
Requires: unknown
14.9" (380mm x 32mm) Front Brake Upgrades
Requires: unknown
Requires: unknown
REAR BRAKE UPGRADES
12.2" (310mm x 22mm) Rear Brake Upgrades
Audi S3/TT 3.2l/VW R32 310mm Rear Big Brake Kit (310mm x 22mm) $695+
Comes with:OE rotors, calipers, carriers and Mintex brake pads
Links to suppliers and manufacturers
AP Racing
Autotech
Brembo
ECS Tuning
Eurospec
Movit
RPI Equipped
Serious Euro Tuning
Stasis Engineering
Stoptech
Old 01-05-2008, 03:58 AM   #10
JudgementDEY
Euro tuned Freak
Drives: 2007 MKV GTI Black Magic
Buddy of mine bought MKV R32 brakes all around for his mkv gti Saved alot of money stops alot better than stock i mean seriouse stopping power.And it cost him 2,500 with installation but he powdercoated them too(porsche Blue" .
Neuspeed P-FLow,NEUSPEED Hi-Flow Turbo Discharge, Hi-Flo Intercooler Pipe,ATP Downpipe,APR Stage 2,Boost gauge,H&R Sport springs,smoked side markers.
FAST IS MY CO-PILOT
JudgementDEY is offline   Reply With Quote
Old 01-05-2008, 12:22 PM   #11
absoluteczech
GolfMKV ADMlN
2500!? dude r32 brakes are 1k unless he got front and rears?
Old 01-05-2008, 12:51 PM   #12
Dan GSR
Dan GSR's Avatar
Drives: 06 GTI
Send a message via AIM to Dan GSR
ShadowGLI great post
good to have all the info in one spot
Dan GSR is offline   Reply With Quote
Old 01-05-2008, 01:06 PM   #13
Dan GSR
Dan GSR's Avatar
Drives: 06 GTI
dont forget these
around $10k
http://forums.vwvortex.com/zerothread?id=3419407
Old 01-05-2008, 05:06 PM   #14
absoluteczech
GolfMKV ADMlN
installing those next week :laugh:
Old 01-05-2008, 06:16 PM   #15
ShadowGLI
ShadowGLI's Avatar
Old 01-11-2008, 01:18 AM   #16
JudgementDEY
Euro tuned Freak
R32 brakes
Yea he got front and rears and got them powder coated Porsche mexicana Blue. They look Sick!!!
FAST IS MY CO-PILOT
Old 10-26-2009, 12:13 PM   #17
agrin2005
Livestrong
agrin2005's Avatar
Drives: 07 MKV Reflex Silver GTI
Send a message via AIM to agrin2005 Send a message via Yahoo to agrin2005
Any Ideas on who makes better stock disks.. I want to install cross drilled disks and not sure what pads to use.. I am running a stock 07 2.0t FSI ..
agrin2005 is offline   Reply With Quote
Old 10-26-2009, 12:26 PM   #18
julito04
I plead the fif.
Drives: Scoobaru tyrannosaurus WRX.
Send a message via AIM to julito04 Send a message via Yahoo to julito04
Wow. $2,500
-_- AEM - Cobb - Rally Armor - Kartboy - SPT - BC Racing - Whiteline -_-
If you say "jesus" backwards, it sounds like sausage.
julito04 is offline   Reply With Quote
Similar Threads
F.S Willwood Big brake kit frank2287 Classifieds - Buy, Sell and Trade 9 12-02-2008 03:22 PM
*MKV GTI BIG BRAKE KIT! DTMRyan SPONSORS Classifieds Area 11 01-21-2008 04:56 PM
GIAC/VF Engineering RSS Turbo Kit Pictures and Dyno Gregg@AutoDrmz Engine / Drivetrain / Exhaust 70 09-26-2007 09:43 PM
Big Brake Kit with stock wheels??? Mr Baytchos Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 3 06-27-2007 06:43 PM
AFTERMARKET LIGHTWEIGHT UPRATED FRONT BRAKE KIT Hotshot 5 Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 1 09-06-2006 06:45 AM
