Old 11-29-2007, 02:11 PM   #1
ratboyyy
Cubicle Worker
Drives: 07 GTI DSG 2DR
Weird Boost Leak
i'm losing 3psi across the board, my MPG dropped too, no oil that i can see around the area of the oil filler cap, i have the Forge DV, stg 2 apr, 12K on the car
sometimes i get this really weird "tuh" noise when i accel then let go of gas, it is a deep "tuuhhh" noise, only way i can explain it
so i look under the hood, take cover off, and start messing with the thingy that is connected to the line that i put my vac/boost guage line and DV line too. the thing to the right of it, where i had to cut 2 nipples off of to slide the piece of tube on it
well everytime i lift it up, which in turns lifts the whole line where the boost guage and dv line is hooked up too, i can hear air coming out, weird, then all the air runs out of course since the car is turned off, i used clamps to attach the lines, but didn't use anything at that metal piece where you can connect the boost guage and dv line too, the one that was provided by FORGE
at work now so will clamp that off when i get home, but you guys think that is the case? would it really affect MPG if that was where the leak was?? any help is appreciated
02 CL TypeS / 02 Prelude / 99 Civic SI / 07 Civic SI sedan / 02 EP3 Civic SI / 03 1.8T Wagon / 06 V6 Mustang x2 / 00 WRX / 07 WRX / 05 Corrola TypeS / 96 Talon / 05 Celica GT-S / ?? Nissian SE-R
ratboyyy is offline   Reply With Quote
Similar Threads
Chipped; Turbo or boost leak? mose6161 Engine / Drivetrain / Exhaust 19 11-23-2007 01:43 PM
Boost "Issue" (Graphs included) tharsis Engine / Drivetrain / Exhaust 12 08-06-2007 10:53 PM
i think i blew!! my PCV VALVE or my DV or maybe i have a boost leak.. i need help!! Gabster Engine / Drivetrain / Exhaust 39 02-22-2007 09:09 PM
Boost leak? EVOMS problem? itisagoodname Engine / Drivetrain / Exhaust 14 01-19-2007 03:44 AM
Boost Leak...please help 06gtimkv Engine / Drivetrain / Exhaust 9 10-01-2006 08:36 PM
