Old 11-15-2007, 02:32 AM   #1
allx11
allx11's Avatar
Drives: MKV RS RABBIT, E90 335I
Offset Formula
Any one have the formula to figuer out the offset on wheels?
allx11 is offline   Reply With Quote
Old 11-15-2007, 03:49 AM   #2
MHS216
Anchors Aweigh
MHS216's Avatar
Drives: 06 United Grey GTI
Send a message via AIM to MHS216
It's at the top of the wheels/tires/suspension sub-forum. A big red button that says "Golfmkv W/T Calculator."
Or do you mean if given a certain wheel, is there a way to figure out it's offset? In that case I don't know, but in some cases it's printed on the back side of a wheel. It will say "et45" for a 45 offset for example.
Matt-Because signatures offend the elite.
MHS216 is offline   Reply With Quote
Old 11-15-2007, 03:53 AM   #3
335 Trojan
Macro FTW.
335 Trojan's Avatar
Drives: 2007 e92 335i Space Grey
I see no such button lol....
FS G36C Airsoft Rifle + Mags + Scope + Accessories
http://www.golfmkv.com/forums/showthread.php?t=112148
335 Trojan is offline   Reply With Quote
Old 11-15-2007, 03:55 AM   #4
MHS216
Anchors Aweigh
MHS216's Avatar
You lie!!!
Old 11-15-2007, 03:59 AM   #5
335 Trojan
Macro FTW.
335 Trojan's Avatar
You lie!!!
screenshot it then lol.
no joke here
Old 11-15-2007, 06:47 AM   #6
MHS216
Anchors Aweigh
MHS216's Avatar
I don't know how to do a screen shot. It's on the page that list all the threads in the "Wheels/suspension/brakes" sub-forum. It's toward the top of the page, to the right in the middle. It's a red box that says "Golfmkv W/T calculator". I'm using version 3 "fast" of the forum, I don't think that makes a difference though.
Edit: Very weird, I checked the other ways to display the site, and this button only appears if you select the "3 Fast" mode of viewing. I'm talking about going to the bottom left corner, and choosing the "quick style chooser". See if it shows up if you choose "fast"
Old 11-15-2007, 10:19 AM   #7
allx11
allx11's Avatar
Yeah these wheels don't have it stamped on the back like normally, they are custom built wheel's.
The WT calculator just tell's you what tire size to use when fitting after market wheels.
I'm not sure if it was on this forum or on the vortex some one posted a illustration with a formula showing what you need to meassure , and using the formula would give you the offset of the wheels.
Thanks for the input guy's I'll keep searching.
Old 11-15-2007, 10:20 AM   #8
Widebody MkVer
Performance Infused Style
Widebody MkVer's Avatar
Drives: Widebody MkV
http://www.1010tires.com/WheelOffsetCalculator.asp
Sig by Sloppy
My Brute
Widebody MkVer is offline   Reply With Quote
Old 11-15-2007, 10:45 AM   #9
EL PAALO
FWD FTL
EL PAALO's Avatar
Drives: '07 GTI
Send a message via MSN to EL PAALO
http://www.mr2.com/forums/wheels-tir...flushness.html
wheelspecs.com
sasca.org
spokes.org
EL PAALO is offline   Reply With Quote
Old 11-15-2007, 12:58 PM   #10
svt2mkv
Touring Car Champion
svt2mkv's Avatar
Drives: 2009 Cobalt Blue Jetta
I think that you just measure the with of the wheel on the inside without a tire mounted (between there the beads sit). Then measure the distance between the back of the hub to the back of the wheel. Subtract .25" from the back-spacing measurement (this is roughly the thickness of the bead lip) and convert both numbers to mm. Now, subtract the back-spacing measurement from the width. This willk give you a rough idea of the offset (measuring the width of the bead lip will give you a more accurate number).
Negative Cassie, computer control.
svt2mkv is offline   Reply With Quote
Old 11-15-2007, 01:05 PM   #11
EL PAALO
FWD FTL
EL PAALO's Avatar
Drives: '07 GTI
measuring OFFSET -
LOOK AT THE FRIGGIN' WHEEL before you bother measuring
http://carpron.com/albums/album16/DSC01493.sized.jpg
many wheels have all the pertinent info stamped on the back somewhere, generally between the mounting points or on the back of the spokes. oddly, some of the pricier makers like volk use stickers that often get taken off for whatever reason. if your sticker is gone or there's no info on the back, start measuring (take the wheel off first).
you need:
1. something to lay across the back of the wheel. flat, not bent, doesn't bend. something with definite edges is good. I used a large ruler sideways so I wouldn't have to worry about it flexing.
2. some change if the tires are still on the tires (to put between the flat thing and the wheel edge since many tires overhang the wheel and will screw up the measuring). I used a quarter and a penny which equal 3mm in width (measure your own change just in case - especially folks not from the U.S. ;) )
3. a measuring implement ....... I used a tape measurer, but you could use just about anything and just mark it and measure the marks with a ruler later if that seems easier to you.
4. paper and pen if you're like me and forget numbers all the time.
Alright, time to measure.
1. Measure the width of the wheel from outermost edge to outermost edge. The wheels I measured came out to 10" on the tape measurer. The actual width of the wheels is 1" thinner than measured due to the flanges being 13mm wide on either side. So, the number I write down is 9".
2. lay the flat thing across the outermost portion of the wheel. if there's tire in the way, use the change (quarter and penny in my case) to find the error (3mm in my case).
3. measure from the mounting face of the wheel (the part that actually touches the hub on the car) to the flat thing. the number I got here was 151mm.
now for simple math.
1. take the width and divide by 2. 9 divided by 2 = 4.5" for me.
2. convert half the width to mm. 4.5" = 114.3mm
3. subtract that from the total measurement (151mm in my case). 151 - 114.3 = 36.7
4. subtract the error (if any) from 36.7 - 3 (the quarter and penny) = 33.7mm
5. subtract 13mm for the backside flange that was included when you measured. 33.7 - 13 = 20.7mm
offset = 20.7 according to my measurements. actual offset (stamped on the back of the wheel) is 20 so good enough considering my crude implements. Use quality tools and measure multiple times to ensure accuracy. I was only .7mm off with a camera in one hand so if you have somebody there to help you and are careful it should be no problem.
13mm is the width of J or JJ flanges. There are some exceptions like JK maybe ..... haven't seen a width measurement for that flange and HRE uses a different size (unknown to me) also. CCW and some other custom wheel makers may also use something slightly different. Almost any wheel you run across will be J or JJ though.
wheelspecs.com
sasca.org
spokes.org
Old 11-16-2007, 02:06 AM   #12
allx11
allx11's Avatar
Thanks for chiming in guy's got the problem sorted out...
Similar Threads
HELP with offset? phxturbogti Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 12 06-15-2007 05:34 AM
ok, lets solve the real deal on +35 offset. elude Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 172 05-24-2007 12:53 AM
Offset Question CiaranGTI Australia 9 05-15-2007 03:19 AM
Quick Offset Question vwsuperhero Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 6 02-22-2007 01:18 AM
Wheel offset! (not a question) Sickspeed06 Wheels / Tires / Suspension / Brakes sponsored by The Tire Rack 3 10-24-2006 08:50 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
