Old 11-09-2007, 01:26 PM   #1
jbres79
Drives: 2002 Camaro SS/07 GTI
HARD START
Hi All, the search funtion is giving me some problems so i need to start a new thread.
Has anyone else had a problem with their GTI's having a hard start in the morning or when the engine is cold?
My 07 GTI stumbles or hesitates when i turn the key to start the car. after the engine turns over and starts its fine and idle is good. Sometimes the engine acts as if it does not want to start.
i took the car into service, they did some software updates but it does not seem to have helped.
any info will help. thanks
07 GTI
2002 SS A4
13.3@105
jbres79 is offline   Reply With Quote
Old 11-09-2007, 01:57 PM   #2
mose6161
OUT OF COMMISION
Drives: .
if you looked at the forum yesterday you'd know the answer to this
mose6161 is offline   Reply With Quote
Old 11-09-2007, 02:04 PM   #3
Chongman805
have a BIG one ;-)
Chongman805's Avatar
Drives: CANDY
Send a message via AIM to Chongman805 Send a message via Yahoo to Chongman805
the same thing happens to me. 3 times of cranking it and nothing but a "oil pressure too high" I have actually got warning lights and dinging, as well as my EPC flashing and the warning saying to take car to dealer immediately. I've had the oil can Icon on my MFD too. I've had my car in and tested somewhere better than the dealership and my car is 100% fine.
Ummmmmmm What?
Go Cry Emo Kid........
www.Dub-Nation.com
http://www.bshftw.com <----only stop you need for all your Dub Part's!
Chongman805 is offline   Reply With Quote
Old 11-09-2007, 02:41 PM   #4
2zzge
2zzge's Avatar
Drives: '07 BMP GTI
there's a generic list of things and a specific list of things that can cause "hard starts".
some generic (not GTI/VW specific) stuff to check: (assuming everything is actually working normally)
  • higher octane fuels are often harder to ignite in colder conditions. the closer to freezing it gets, the harder is may be to ignite.
  • "loose" compression can make for hard starts. often times, after a cars sits for a while, the film of oil on the cylinder wall disipates enough to actually loose a bit of compression. its normal, but some cars are more prone and/or susceptible.
  • sometimes the fuel in the lines partially cyphens back into the tank. this means it may take a few more cranks of the engine to get the fuel back to the motor.
some VW specific stuff to check into:
  • all of the above
  • there have been issues with the fuel delivery system on these cars. you may be experiencing what has now been determined as "normal faults" such as
  • low pressure fuel pump
  • fuel filter/regulator (low pressure end)
  • high pressure fuel pump/regulator
  • HPFP cam lobe assembly (early builds were made with a defectively soft cam (it runs the high pressure pump)
  • coil packs
  • software (which you have already had 'fixed')
that's all i can think of off of the top of my head....all the best to you man.
2zzge is offline   Reply With Quote
Old 11-09-2007, 03:43 PM   #5
jbres79
thanks for the quick and knowledgeable replies guys.
Its strange because the car runs copmletely nornal after the engine fires. its just having a hard time starting. it kinda struggles to turn over. Im using sunoco 91 and its been about 30-50F degrees outside this week.
If anyone else can think of something else I can talk to VW about please let me know. I will try to find the thread that "mose6161" is talking about.
edit:
a few other points:
- hard start was happening in mild weather as well (50-70F) so it isn't just cold weather.
- according to the technician, no faults were being registered.
07 GTI
2002 SS A4
13.3@105
Old 11-09-2007, 05:10 PM   #6
Superted
Seat Leon 2.0TFSI
Superted's Avatar
Drives: 2.0TFSI
edit:
a few other points:
Don't worry old boy it's not a conspiracy, it's happening over here too! This has been happening to mine for some months, all through the summer ('what summer i here you ask') mild weather even, and now cold, seems to be better.
Dealer had for three days and no fault found, in fact, it started bang on each morning they had it................ How mad can one get...
Superted is offline   Reply With Quote
Old 11-09-2007, 05:11 PM   #7
Superted
Seat Leon 2.0TFSI
Superted's Avatar
Drives: 2.0TFSI
Didn't look so don't know..........any clues????
Old 11-11-2007, 01:25 AM   #8
Chongman805
have a BIG one ;-)
Drives: CANDY
I don't know the credibility of the so called "moses6161" I would just refer to this thread.
Ummmmmmm What?
www.Dub-Nation.com
Old 11-26-2007, 10:35 PM   #9
jbres79
ok, i know the quality is not great with this vid, but turn up your volume and you can listen to an example of a rough start i am having. Pay special attention to the RPM's on start it. it actually stops and sputters at 500 for a second or two. on a good start this does not happen as the RPM's climb smothly to about 1,200 or so.
please let me know if anyone else has this or has any further ideas of what the problem is. The dealership is not finding any error codes so they have not done anything to fix it.
http://jbres79.googlepages.com/bad6.avi
07 GTI
2002 SS A4
13.3@105
Old 11-27-2007, 10:59 AM   #10
2zzge
2zzge's Avatar
Drives: '07 BMP GTI
up until about a month or so ago, my car was having some rough idle issues. it made for some difficult cold-starting and would idle rough. (mostly just a bit of 'coughing' and 'missing'...not severe)
about 6 or 7 times it actually was severe. spit and sputtered, choked and misfired and barely was able to idle above 400rpms...let-a-lone idle at all.
it turned out to be one or more coil packs.
the dealer was nice and honest. they told me that there was nothing to be done until a "code" was logged. because of that i just swapped them out on my own, cash out of pocket.
FIXED!! yeah!!!!!
fast foreward 6 weeks or so to the present.
a (not so) funny thing has happened in the past two days.
after the car has been sitting overnight and i go to start it on a cool (for aournd here) morning ~50*, the engine just turns over....doesn't fire at all.
just cranks away.
as soon as i stop turning the engine over, go to try again, it fires right up. idles fine.
i think on my car, (i'll have to take it in to the dealer to be sure) but i think the fuel is cyphening back into the tank.
if i'm not mistaken, there's a sort of check valve somewhere back by the tank. either in the filter or by the low pressure pump.
crap.
sorry for the hijack...just wanted to let you all know that these two things could very easily have happened at the same time instead of being spaced out over a month or so.
you may have more than one issue with your car at the moment.
VW knows about these issues as they seem to be common enough...but most dealers won't 'fix' it if they can't produce it themselves and/or if there isn't a CEL.
sorry for the long post...its still early here on the left coast
Old 07-18-2010, 06:33 PM   #11
boomergti86
j-dub in da haus
boomergti86's Avatar
Drives: 2009 VW GTI MkV
I'm having the same issues as jbres79. Started my car this afternoon, 104 F, and hear a somewhat loud "pop" from the engine and felt the vibration in the brake pedal. The engine started and idled fine, though. I took the car into the Dealership and they were never able to replicate the issue or find any problems. The problem seems to be intermittent. I guess all we can do is hypothesize why this is happening until the dealer can actually get the engine to start bad....
boomergti86 is offline   Reply With Quote
Similar Threads
Remote Start? RJS5689 GTI / Rabbit / Golf MkV General Discussions 31 11-12-2008 06:31 PM
Its a start Blackghost20t Photo / Video / Media Gallery 11 03-23-2007 05:49 PM
UBER TURBO LAG OFF THE START... DSG LiquidG GTI / Rabbit / Golf MkV General Discussions 10 11-27-2006 01:23 AM
Won't Start MRSiGTi GTI / Rabbit / Golf MkV General Discussions 5 10-16-2006 08:11 AM
how to start your own garage? bennylenny88 Off-topic / Misc. 21 07-31-2006 04:20 PM
