Yes, get the cover. :w00t:
I got mine here <http://www.carcoversdirect.com/products/car_truck_covers/6/car_cover/custom_fit/VOLKSWAGEN/2007/RABBIT/2.5/48/4/>
and I'm very happy with it :clap: .
It's not a perfect solution (a garage) but the benefits outweigh the negatives. It's not just the paint you're protecting, but everything the sun (UV), acid rain, etc. touches on your car. Rubber doesn't deteriorate
, black trim stays black :smile: , the interior stays cooler
, (some) protection against door dings :thumbsup: , etc. Plus, you just feel better knowing you're car's wrapped up in its own little "cocoon". :wub:
On the down side, the Evolution fabric is so light that putting the cover on in a breeze can be fun until you get a system down. The fabric's a little stiff and bulky when new, but becomes more flexible quickly. The inside is very soft and will "absorb" some dirt so I don't think scratching your car is a problem (it hasn't been for mine) unless you put it on over a muddy car. Plus, the cover's washable. You'll need to install a grommet (included, I think) for the antenna to poke through, or remove the antenna each time you put it on. If you do that, the antenna base will eventually abrade the cover, so you should reinforce the area where it rubs with some glue-on fabric.
I got the custom fit cover (not the ready fit) and it fits perfectly.
I put my license # on the back of it to discourage theft (use T-shirt spray paint from a craft store, not regular paint or permanent markers) and I got the optional lock and cable that goes under the car to "lock" the cover on.
