I have an 08 gti fsi. The car sounds like its misfiring and shanking terribly. I don't even want to move it let alone even turn it on. I'm worried it may be the hpfp has failed. I pulled out the follower and it looks good but I do see scuffs on the camshaft. I got it on a vag com today here are the logs... The vehicle has 104000 miles on it
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G93NM89G
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 3668F8144182DBAE71B-8063
4 Faults Found:
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 165429 km
Time Indication: 0
Date: 2000.00.00
Time: 14:18:46
Freeze Frame:
RPM: 1287 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 11.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.811 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166755 km
Time Indication: 0
Date: 2000.00.00
Time: 11:50:44
Freeze Frame:
RPM: 3508 /min
Load: 8.6 %
Speed: 144.0 km/h
Temperature: 74.0°C
Temperature: 18.0°C
Voltage: 14.478 V
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166949 km
Time Indication: 0
Date: 2000.00.00
Time: 18:29:31
Freeze Frame:
RPM: 1190 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 14.0°C
Voltage: 14.605 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 166949 km
Time Indication: 0
Freeze Frame:
RPM: 1203 /min
Load: 43.9 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 14.0°C
Voltage: 14.605 V
Readiness: 0000 0101
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 165429 km
Time Indication: 0
Date: 2000.00.00
Time: 14:18:46
Freeze Frame:
RPM: 1287 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 11.0°C
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166755 km
Time Indication: 0
Date: 2000.00.00
Time: 11:50:44
Freeze Frame:
RPM: 3508 /min
Load: 8.6 %
Speed: 144.0 km/h
Temperature: 74.0°C
Temperature: 18.0°C
Voltage: 14.478 V
P1297 - 001 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 166949 km
Time Indication: 0
Date: 2000.00.00
Time: 18:29:31
Freeze Frame:
RPM: 1190 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 14.0°C
Voltage: 14.605 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 166949 km
Time Indication: 0
Freeze Frame:
RPM: 1203 /min
Load: 43.9 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 14.0°C
Voltage: 14.605 V
