This DIY is writen assuming that the installer already has an ipod adapter installed. If you need assistance installing the ipod adapter see this DIY http://forums.vwvortex.com/zerothread?id=2480895
Tools needed:
-ipod adapter
-torx screwdriver
-flathead screwdriver
-dremel or other cutting device
-ipod dock (comes with ipod)
-epoxy
-pliers
Step 1
Remove shifter cover. Use a trim tool remover or a flathead screwdriver.
Step 2
Once the cover is removed unscrew the 2 torx screws holding the coin tray in place.
Step 3
With the coin tray lifted unhook the ESP and the 12V connections
Step 4
Pull the coin tray out.
*Becasue im writing this DIY after i completed this install i only have pictures of the final look and not the step by step process. Sorry*
Step 5
Using the dremel or other cutting device cut a hole in the bottom of the coin tray large enough for the ipod dock to fit snug.
Step 6
Epoxy the dock to the coin tray and allow to dry.
Step 7
On many ipod dock connectors there are hooks that keep the ipod connected. These hooks must be removed using pliers which allows the ipod to be removed from the dock without having to squeeze the cable head.
I hope this picture gets the idea across...eh, u'll figure it out.
Step 8
Epoxy the ipod adapter cable to the bottom of the ipod dock.
Step 9
Cut a hole in the black rubber mat to allow the dock to be shown from the top of the coin try and to hide and blemishes.
Step 10
Reassemble
Step 11
Your job is done, B.
