markcaughey
- Glasgow
Basically as the title says
Removed the tails todo this but I found it easier to mask the circles out while still on the car. I have applied the tint by adding 2 pack black to some laquer, just start with a little and work your way up to get to the level of darkness you desire. Also remember to give all 4 parts of the tail lights the same number of coats from the same mix ( laquer:2 pack) to keep the colour match the same. At the moment I have just applied the tint but once that is dry I will flatten with p1500 wet grey scotch brite and then apply clear coat over the full light this will remove the edge caused by the tape.
