thunderous1
a proud new owner
- L O N D O N
- black magic mk5 gti
just got a bargain full front set, do these go straight on or what else do i need to fit these bad boys :readthethread:
wont i need different offset wheels?
Yes, wheel options from factory are limited for the TT-RS due to brake size.
Believe me, the TT-RS/RS3 master cylinder IS neccessary to keep pedal travel short und pedal feel stiff.
Why? Because these Audi TT-RS calipers are designed to work with a 25 mm master cylinder.
Audi didn't intend to fit this brake to a Golf.
I also NEVER would install Cayenne calipers to a GTI. The longer pedal travel you experienced
indicates there is something wrong. More specific: the calipers pistons are too large. This will
change brake balance, brake booster charateristics (keep im mind the GTI one is 'dual rate'),
hysteresis and brake assist threshold.
Shurely the car will get increased stopping distances !!
Why spending that money to make things worse?
Volkswagen spent years to optimise braking on the GTI. Of course it is possible to improve
things, but to make it better you need to know about it. Brake hydraulics, brake electronics,
pad materials and so on.
If Audi designed the RS calipers to work with a 25mm master cyl I'd be inclined to match up the correct parts. The perceived size of the caliper is less important than the piston area you're trying to push. There are plenty of upgrade paths that will work fine with our stock master though. My car worked well with R32 brakes front and rear, I've driven other dubs with bigger brakes and didn't note anything weird or wrong with the stock master or the brake action.
MANY people on this forum have 4 piston BBK kits with pistons that look larger than the TTRS ones.
I don't see what the hesitation is to just bolting these on, bleeding them, and seeing how it goes?
No doubt when fitting S3/R32 brakes on a Mk.V GTI (22,22 mm MC) you get increased pedal
travel. A bigger MC reduces wheel travel. Both is simple physics.
- 22,22 mm (Mk.V GTI)
- 23,81 mm (Mk.V R32, Mk.VI GTI, Golf R)
- 25,40 mm (RS3 + TT-RS)
That's the way it is at least in continental Europe. RHD cars at least do come with different
brake booster.
From what I read unfortunately the 25,40 mm MC does not fit smaller brake boosters.
Interesting to see VW changed from the small 22,22 mm MC on the Mk.V GTI to the same
23,81 mm MC the old R32 already had. That does mean a Mk.VI GTI is better prepared for
fitting R-brakes than the Mk.V GTI.
