On the Mark VI forum, there have been concerns over whether the TSI engine (which I believe replaced the FSI's sometime in 2008) is prone to oil surge / oil blow by on high speed left hand turns:
http://www.golfmk6.com/forums/showthread.php?t=34394
http://golfmk6.com/forums/showthread.php?t=17181&highlight=oil+smoke+track
The theory is the risk of oil surge (or oil blow by through the PVC, into the intake stream, through the turbo and which gets bured up in the motor) may cause complete engine failure and that running r compound tires only increases this risk. When this reportedly happens, it manifests in smoke blowing out everywhere--though it does not necessarily result in complete engine failure. Does anyone on the Mark V forum have any commments or experience with this? Is ultimate engine failure from high g turns (like when running r compounds) a legitimate concern with our cars?
I have a Mark VI and currently run 225/45/17 Nitto NT-01s with hotchkis front and rear sways set to medium while competing in NASA TTE. Otherwise, my suspension is stock. Thus far, after two full weekends at Gingerman and Autobahn, I have not noticed any smoke coming from the exhaust or any other sign of this oil surge / oil blow by. To run NASA TTD, I would need to step up my suspension and tires. However, before investing in coilovers, sport spindles, camber plates and hoosier A6's, I would like to know whether there is a reasonable risk that I could blow my engine on high speed turns with this set up? I have heard other types of cars have had this problem but I don't know if ours do.
For those who run r compounds (or near r compounds) and have a TSI engine, please post your experiences. Please also describe the specific suspension and tires you have used. For anyone else who has thoughts on this subject, please feel free to share them.
Thank you in advance...
