Old 07-29-2012, 07:53 PM   #1
dddrew.
blah.
dddrew.'s Avatar
Drives: 2009 GTI (2DR TSI)
18x8.5 ET35 flush or poke?
Sorry for another stupid thread but i figure i'd get better responses in here instead of my old thread with a different title.
I'm looking at getting a set of BBS RG-II since i'm starting to realize it'll be impossible to find used BBS LMs under $2500. I found a set of RG-IIs but im not sure if i'll like the offset. My car is lowered on koni coilovers all the way with rear perches out. Still only a moderate drop.
How would 18x8 +40 front, 18x8.5 +35 rear look? Like i've said in previous threads im not a fan of poke at all but have to live with some if i plan on getting a set of BBSs it seems.
Picture of my current stance:
(click here for full size for a better look)
lameroll1 by dndandrea, on Flickr
Just looking for someone who has past history of wheels with these specs.
I'd also like to know how my 225/40/18 tires would work on it or if i should break the bank and get some new ones.
dddrew. is offline   Reply With Quote
Old 07-29-2012, 07:58 PM   #2
FaLLeNAn9eL
look at my fanny
FaLLeNAn9eL's Avatar
Drives: black racekar
You need to talk to Phil Chow.
i ken lee libu dibu douchoo.
FaLLeNAn9eL is offline   Reply With Quote
Old 07-29-2012, 08:00 PM   #3
steveo17
GIAC Stage 2
steveo17's Avatar
Drives: 2006 CW GTI
Send a message via AIM to steveo17 Send a message via Skype™ to steveo17
it will be pretty much flush with the fenders. 215/40s or 215/35s all around and youre golden
"A lot of people think his car is not functional, but to him it is the definition of functional because every time he gets behind the wheel it puts a smile on his face, and that is all that should matter to any car owner."
steveo17 is online now   Reply With Quote
Old 07-29-2012, 09:10 PM   #4
itskv
APR Stage II+
itskv's Avatar
Drives: 2008 BMP GTI
buy my alphards, perfect fitment
3M | Air Lift | APR | AWE | BSH | JL Audio | Kenwood | KSport | Neuspeed | NGK | Nokya | VF Engineering | Votex
itskv is offline   Reply With Quote
Old 07-30-2012, 12:08 PM   #5
Bunnspeed
Salad Tosser
Bunnspeed's Avatar
Drives: 2008 UG GTI 4 door
This is good info. I had VMR V710s, 18x 8.5 et45 all around and they were flush if not ever-so-slightly poked (like, by a mm or two, tops) up front, but a little more recessed in the rear. I always thought ET35 in the rear would have been perfect, so I think that'd be spot-on for your fitment. 18x8 et 40 should look great up front and be pretty much perfectly flush IMO, like steveo17 said.
I had 225s and they fit fine at my higher ride height, but if you are as low as your sig suggests, steveo's recommendation to go with narrower tires would be a good one, otherwise you're likely to rub.
UG 6MT 5 door GTI K04
White 1997 Cadillac DeVille
a.k.a. The Marshmallow Warhammer
Bunnspeed is offline   Reply With Quote
Old 07-30-2012, 12:23 PM   #6
tomshouse516
tomtomtomotomtomtomtomtom
tomshouse516's Avatar
Drives: 09 GTI DSG
That would be a nice flush fitment, you might need a touch of negative camber in the rear but not much.
I would suggest 215/40 but you could get away with 225/40 for now if you don't lower your coils all the way.
BUILD
tomshouse516 is offline   Reply With Quote
Old 07-30-2012, 12:39 PM   #7
dkwince
BIG WILLIE STYLE
Drives: Moon Rover
My old set up. I was running 215/40 Sumitomo HTR Z III. FTG was anywhere from 22.8" to 23"
fitment by Dustin Wince, on Flickr
Untitled by Dustin Wince, on Flickr
rears with -3* of camber.
dkwince is online now   Reply With Quote
Old 07-30-2012, 02:52 PM   #8
dddrew.
blah.
dddrew.'s Avatar
Thanks, I sent him a PM yesterday.
Well this makes me feel better, thanks for the info.
Sorry but not really interested in alphards anymore.
Great information from both of you guys, thanks. Sounds like i'll definitely want new rubber if i decide on getting these wheels.
These are 18x8+40, 18x8.5+35?
Old 07-30-2012, 03:00 PM   #9
mobbin6
Formula 3000 Driver
Drives: Gti
no, those were 18x8.5 et35 all around. Here's an older shot of my car, 18x8.5 et35 with a 215/35/18 tire with about -2 degrees camber.
Useless
mobbin6 is offline   Reply With Quote
Old 07-30-2012, 05:29 PM   #10
dddrew.
blah.
dddrew.'s Avatar
Left or right car?
Something tells me it's the left car but that is farther out than I planned...
Old 07-30-2012, 05:47 PM   #11
dustinwark
Vorsprung Durch Technik
dustinwark's Avatar
Drives: APR tuned 2.0TFSI, '66 Type 1
vrwheels has LMs for under that all the time
Dustin Wark | automotive + photography (Flickr) + cinematography (vimeo)
dustinwark is offline   Reply With Quote
Old 07-30-2012, 06:58 PM   #12
mobbin6
Formula 3000 Driver
Drives: Gti
Left or right car?
left car. Keep in mind, for many mkv's, one side always pokes more than the other. In my case, it's the passenger side that pokes about 3mm more than the drivers side. I ended up throwing a 3mm spacer on the drivers side just to even things out.
Useless
Old 07-30-2012, 07:29 PM   #13
DJ Spice
Touring Car Champion
DJ Spice's Avatar
Drives: 2006 GTi DSG
I just noticed this on my car... Why does this happen?
Sent from my MKV GTi using Tapatalk 2
APR Stage 1/BSH Catch Can/BSH PCV Fix/Neuspeed P-Flo/DV Rev D...
DJ Spice is offline   Reply With Quote
Old 07-30-2012, 07:39 PM   #14
mobbin6
Formula 3000 Driver
Drives: Gti
the rear beam isn't perfectly centered. Something to do with the fuel tank or filler lines.
Useless
Old 07-31-2012, 07:07 PM   #15
phil
IMAGE IS EVERYTHING.
phil's Avatar
Drives: 08 VW GTI
Send a message via MSN to phil
Unrefinished!
BECAUSE RACECAR
[iDub] - VR Wheels - IMAGE IS EVERYTHING.
phil is offline   Reply With Quote
Old 07-31-2012, 10:23 PM   #16
dustinwark
dustinwark's Avatar
Originally Posted by phil View Post
Unrefinished!
He didn't say he wanted mint LMs, just that he couldn't find LMs for under $2500
Old 09-14-2012, 12:59 AM   #17
ModBargains
GolfMkV Sponsor
ModBargains's Avatar
Drives: VW GTI, 335i, 135i, 996TT, 370
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
one of my friend's car , they are 18x8.5 et35 Vmr V701 Gunmetal
- Eddie
VW Golf MKV Exhausts | VW Golf MKV Intakes | VW Golf MKV Performance | VW Golf MKV Wheels
Sales@modBargains.com | Sales@ModBargains.com| (714) 582-3330 ext. 8006
Address: Hours: Monday - Friday 8:00am-7:00pm, Saturday 8:00am-5:00pm (PST)
ModBargains is offline   Reply With Quote
Old 09-14-2012, 07:33 PM   #18
VMRWheels
GolfMkV Sponsor
VMRWheels's Avatar
Drives: 2008 TR R32
I would not necessarily recommend that fitment. A 35 offset is a little aggressive for your car and would most likely require some type of fender modification to fit.
JB @ VMR | Wheels
Email: JB@velocitymotoring.com | Facebook |Flickr | Twitter | Blog
VMR Collection >> V701 | V708 | V709 | V710 | V713 | V718 | VB3
VMRWheels is offline   Reply With Quote
Old 09-15-2012, 12:56 AM   #19
paulnur
Rookie
paulnur's Avatar
Drives: 2008 GTI FSI MK5
paulnur is offline   Reply With Quote
Old 09-25-2012, 02:10 PM   #20
GTI4John74
Formula 5000 Champion
GTI4John74's Avatar
Drives: CW '08 MK5 GTI 6MT
now i see why my left side tends to look like the wheel is tucked in compared to the passenger side...
2008 GTI FSI 2.0T 6MT 5 Door Stage 2+
034 Motorsport | H2Sport | CTS Turbo | 42DD | V-MAXX | ECS Tuning
OEMPlus | TyrolSport | Neuspeed | Grüvenparts | OSIR
GTI4John74 is offline   Reply With Quote
Old 09-25-2012, 07:36 PM   #21
the bruce
atom heart
the bruce's Avatar
Drives: GTI Mk.V 2008 2-d
agree
This is 8.0x19 ET45 with 225/35 R19 and NO spacers a yes - IT DOES RUB !!
BBS, Ferodo, H&R, OEM VW + TT, S3 & RS3 parts, aerodynamics,
Sachs Performance, Supersprint, SuperPro, Tarox, Whiteline
PICS
the bruce is offline   Reply With Quote
