Kieran_l
- Gold Coast
Guys,
After reading through the forums and various internet posts, im a bit insure what i require to read engine faults.
I have come across the ross tech unit http://www.ross-tech.com/vag-com/Micro-CAN.html, but do i need something like this for just home use, or is there a more simple(cheaper) option that will still give me the same result. As i understand the Ross Tech will let me reset service lights etc, but thats no necessarily required.
The engine isnt showing a CEL but is not running correctly (missing when under cold load) so would like a unit which is mobile and can be left in while driving the care to see if any error codes come up (will a code still be displayed even if a CEL does not come up)?
If someone could recomend a way to go it would be much appreciated?
Thanks,
Kieran
Thanks,
Kieran
