Kit Contains
-Pair of Porsche Boxster (non-s) 4 piston *Brembo* calipers. (These are used but I checked each seal/piston for tears/cracks/damage ) (Calipers are painted with red high temp VHT caliper paint/clear along with high temp porsche decals applied)
-Pair of Zinc coated custom brackets by well known company.
-High grade 12.9 bolts and for mounting calipers to brackets.
-Pair of stainless steel front brake lines.
These brakes are seriously amazing and a much better choice for the price than any BBK available.
Answers to your questions
Everything needed to mount these brakes is included (sans brake fluid).
Front brake setup only.
Fits most OEM wheels with 5mm Spacer
Fits OEM Mk5 Spare Tire/wheel with *maximum* 10mm spacer (never tested 5mm)
I can include my used Hawk HPS brake pads
Saves you around 5 lbs of unsprung weight over the stock calipers on GTIs.
Pictures are from when I purchased the brakes, they have some small paint chips from changing wheels and testing fitments.
**Fits over Stock GTI 312mm rotors**
Asking $800 obo
Side By Side with Stock:
Unfortunately the only picture I have with these brakes on is this:
Asking $800 obo
