Eurotek Tuning
Old 11-25-2011, 03:17 PM   #1
RAudi Driver
unpimp it!
RAudi Driver's Avatar
Drives: MKV GTI, B7 RS4, 997 GT3
P0171 & P0507 Codes just popped up
P0171 read, bank 1 system too lean. I relate this too an O2 sensor but I could be wrong.
P0507 Don't know what this is.
Has anyone had these codes and what turned out to be the issue.
RAudi Driver is offline   Reply With Quote
Old 11-25-2011, 03:23 PM   #2
PRND[S]
The Lame & The Ludicrous
Drives: 2015 Golf R
http://wiki.ross-tech.com/wiki/index...1/P0507/001287
PRND[S] is offline   Reply With Quote
Old 11-25-2011, 03:40 PM   #3
Datalore
Rally Car Champion
Drives: 2007 VW GTI Stock
I have had the P0507 code. The idle would hang, more than usual. I could also put it in third gear and coast @ 1,500 RPM without touching the gas (also on level ground). Any ideas?
Datalore is offline   Reply With Quote
Old 11-27-2011, 09:45 PM   #4
RAudi Driver
unpimp it!
I think that the 0507 could be telling us that we need a new PCV valve.
Does anyone know what if any codes come up if you tear your diverter valve?
Old 11-28-2011, 03:16 PM   #5
Datalore
Rally Car Champion
Not sure of the code #, but you will get an "underboost" code.
Old 11-28-2011, 03:55 PM   #6
RAudi Driver
unpimp it!
I can't believe the lack of traffic on this site
Anyways, I just ordered a new BSH PCV kit with Catch Can. I 'm thinking that my problems are stemming from a bad PCV as I removed the hose this morning, and plugged the manifold hole and everything went back to normal as far as idle.
I'll keep you guys posted
Old 12-11-2011, 02:34 PM   #7
RAudi Driver
unpimp it!
The kit worked and the car is running like a top.
