#1 |
Formula 5000 Champion
![]() Drives: too high Join Date: Oct 2008
Weird Turbo Lag (Stage 2)
My car started acting up today, and was wondering if anyone may have insight as to what's going on.
Things I should mention before moving on: -My PCV is f*cked (oil spewing out of oil cap). Just ordered the BSH revamp. -I have fairly old spark plugs, so they may be bad by now. Have new ones ready to be put in tomorrow night. -Last time I went in for service, VW dealer told me my throttle body needed to be replaced. And now for the issue: I've only tried pulling in 2nd and 3rd gear since I noticed the problem, but the turbo does not fully spool until I hit 3000 RPM. It'll stay rock solid at 5 PSI all the way up, and then at 3k it will go right up to ~18 PSI with no fuss. I'm not sure how long this has been going on as I don't push my car very often at all. I just got in the mood for some spirited driving tonight and it started acting up. Any suggestions and insight on this issue would be much appreciated. Thanks!
#2 |
Almost 60 views and no opinions on this?
Last time this happened, it was a problem with my stock DV. Switched it out for the revision "D"
#3 |
GLI OWNER
![]() Drives: 2006 GLI stage2+, 1989 MK2 GTI Join Date: Sep 2009
Get new throttlebody ? Change plugs, coil packs and seems like limp mode and boost leak somewhere. Stage 2 usually peaks 20-22psi
2006 BMP VW JETTA GLI DSG. APR Stage 2+ ATP DP/Autotech Catback/APR HPFP/BSH Intake/BSH FMIC/BSH VTA Catch Can/Forge DV/Full BSH Engine Mounts/KSport Control V4 Coilovers/VMR Wheels/Full Ice/Newsouth/ instagram: josein06gli |
#4 |
Yeah I'm pretty sure the PCV is what's causing the low boost after the lag. Just wasn't sure what was causing the lag itself. Figured limp mode would be a bit more restrictive.
Anyway, thanks for the response and suggestions!
| Thread Tools | |
