Old 06-04-2011, 07:56 PM   #1
Masdubator
Don't hate, masdubate
Masdubator's Avatar
Drives: 2008 mk5 gti FSI
Stock height with coilovers?
I want to lower my car with coilovers to have adjustable height and performance. I also have to deal with snow for 4 months a year which i need stock height. Are there any coilovers under $1k that will do this?
AFE cai, noisepipe delete, APR stage 1, Rev d DV, audi Rev E coilpacks, ecs dogbone torque mount, AWE downpipe w/ metal cat
Masdubator is offline   Reply With Quote
Old 06-04-2011, 08:51 PM   #2
cskm
Drives: UG GTI
most will be able to give you stock height if they are adjustable. if not as high, it can nearly be just as high.
as for which ones, i have no idea.
cskm is offline   Reply With Quote
Old 06-04-2011, 09:00 PM   #3
65dunebuugy
insert custom title here
65dunebuugy's Avatar
Drives: 06 CW GTI, 01 Jetta Wolfsburg
Konis might. I am in for the results too as I need coilovers that will go kind of low but can go back up to stock height for winter time.
65dunebuugy is offline   Reply With Quote
Old 06-04-2011, 09:04 PM   #4
biggee72
Formula 5000 Champion
biggee72's Avatar
Drives: 1989 Lamborghini LM002
Same issue here. That's why I was just thinking springs but since coils are adjustable I'd be in for a set of these too.
Every year, the world's Golf GTI enthusiasts congregate in a field in Austria, and they talk about fuel injection and wear jumpers with "GTI" on them. Frankly I'd rather blow-torch my nipples off.
biggee72 is offline   Reply With Quote
Old 06-04-2011, 09:15 PM   #5
Masdubator
Masdubator's Avatar
Yeah i was just kinda confused about the sticked thread http://golfmk5.com/forums/showthread.php?t=4. If it says the drop for a coilover is 1.2"-1.8" does that mean the Minimum drop is 1.2" and you can't go any higher?
Old 06-04-2011, 10:07 PM   #6
DavisELK
Oval Newbie
DavisELK's Avatar
Drives: 06 GTI
I found my FK's brand new for 700, and they can get up high enough to deal with ohio snow for the winter if that can answer you.
DavisELK is offline   Reply With Quote
Old 06-04-2011, 10:14 PM   #7
phil
becausephilchow
Drives: 09 VW R32
There really is no coilover that gets to stock height.
Most minimum drops are about 1".
Only way to get stock height is to put back in your OEM suspension for the winter.
BECAUSERACECAR
phil is offline   Reply With Quote
Old 06-04-2011, 11:35 PM   #8
jettagt8v80
I know nothing
Drives: 2006 GTi DSG
Send a message via AIM to jettagt8v80 Send a message via Yahoo to jettagt8v80
koni's get pretty damn close to stock 08 up height
jettagt8v80 is offline   Reply With Quote
Old 06-05-2011, 12:39 AM   #9
GodSquadMandrake
Radioactive Rotary Rocket
Drives: '95 Ẽfini RX-7 Type R
My PSS9's would do 4x4 status easy. It was ridiculous how high they would go. My H&R coilovers were similar but they didn't have quite as much adjustment.
Here's a pic. Hmm not as high as I thought, but I think I raised it up some more after this.
GodSquadMandrake is offline   Reply With Quote
Old 06-05-2011, 01:48 AM   #10
Masdubator
Masdubator's Avatar
wow, i think this might be the answer http://golfmk5.com/forums/showthread.php?t=140104
Old 06-05-2011, 12:12 PM   #11
Simmsled
Parking Garage > Tree
Simmsled's Avatar
Drives: my wife crazy
DO NOT GET KONI COILOVERS FOR STOCK HEIGHT!!! You will experience spring failure!
It may work for a little while, then one day you realize that the front has settled 1/4 inch, then 1/2 inch, then you'll hear the spring start to bind. Do it for long enough, the spring will just keep getting closer and closer to solid (becomes a coiled up stack of metal). I've had many people contact me about this and I've experienced this myself.
Please save yourself the time and agony by NOT going past 25 inches ground to fender on the Koni Coilovers.
DRIVE_
Simmsled is offline   Reply With Quote
Old 06-05-2011, 06:16 PM   #12
V-DubbinLOW
Stanced
V-DubbinLOW's Avatar
Drives: Volkswagen
i got some H&R street performance coils going for 650 lemme know
V-DubbinLOW is offline   Reply With Quote
Old 06-05-2011, 07:34 PM   #13
65dunebuugy
Yours wasn't ones from the batch of bad ones was it??
Old 06-05-2011, 08:15 PM   #14
DUSlider
Rally Car Champion
Drives: 2008 UG Rabbit
How do you know if your coils were part of the bad batch?
DUSlider is offline   Reply With Quote
Old 06-05-2011, 09:10 PM   #15
Simmsled
Simmsled's Avatar
They were not part of the bad batch. The kit is not designed to be used at anything higher than 2 inches below stock height. Front spring failure seems to be why. If you look at the geometry of the front springs, it will make more sense.
DRIVE_
Old 06-06-2011, 01:09 AM   #16
GodSquadMandrake
Simmsled are the Koni coilovers using the same koni yellow shocks?
Would you suggest instead to get the koni yellows with the ground control coilover sleeves?
Old 06-06-2011, 10:48 AM   #17
DUSlider
Rally Car Champion
Yet Koni's website states a min 1.3" drop is acceptable...
I think I'll be getting my warranty replacements and selling them if that's the case... Will be going back to springs and stock struts or a cup kit.
Old 06-06-2011, 02:25 PM   #18
Simmsled
Simmsled's Avatar
Hrmm... good question.
If you are more track/street-performance oriented, yes I would go Koni Sport (yellow) dampers and use the Ground Control coilover sleeves.
If you are more street/low oriented (spirited driving) then the Koni Coilover is a better choice.
DRIVE_
