Old 06-03-2011, 02:19 AM   #1
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
Cel help code P0507
Hey. My car has a cel, code P0507, it says idle air control system rpm higher than expected.
Took it to the dealer they pretty much just said it did it 3 times out of my last 6 drive cycles.
Idk if it has anyhing to do with this but I was teaching my gf to drive standard while it came on so idk.
Current mods k04 and supporting mods
xplicit is offline   Reply With Quote
Old 06-03-2011, 11:03 PM   #2
vwteck1987
Drives: 2007 GTI
P0507 is a fault in the Throttle valve control module J338 (Throttle Body).
Could need re-adapted, could just have a poor connection, i would try unplugging it ( car off ) check the terminals, if ok plug it back in and see if it acts up any more. I work at a dealership and ive seen just unplugging them n plugging them back in fix it...also have had to re-pin the connector for some FSI motors on different models...might be possible that her driving it caused it to through a code, its an electronic actuator so if it is used to your throttle inputs and someone else drives it ( ecspecially getting used to a clutch n RPMs going crazy ) not out of the relm of possibilities
vwteck1987 is offline   Reply With Quote
Old 06-03-2011, 11:17 PM   #3
eurocars
5/17/15 - Never forget
eurocars's Avatar
Drives: GTI
could also be an air leak in or around the manifold/throttle body
eurocars is online now   Reply With Quote
Old 06-04-2011, 01:57 AM   #4
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
thanks for the input guys,
the dealer reset the code and it hasn't come back since ive been driving it, and i probably put about 100+ miles on it and still no cel
Old 06-04-2011, 02:14 AM   #5
eurocars
eurocars's Avatar
Drives: GTI
probably just a fluke then
Old 06-04-2011, 02:20 AM   #6
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
im super paranoid now, if infact something WAS wrong would the cel come back right away?
Old 06-04-2011, 02:22 AM   #7
eurocars
eurocars's Avatar
Drives: GTI
most likely. If it does come back, it wont be hard to diagnose though. Its a simple code
Old 06-04-2011, 02:40 AM   #8
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
it was weird, the dealer said that the car would hold above normal idle for a few seconds before it idled normally,
if something breaks because they didn't take the time to properly diagnose it im gonna blow that place up
Old 06-04-2011, 02:37 PM   #9
alphabits
FIA World Rally Car Newbie
alphabits's Avatar
Drives: '06 GLI
Yea, welcome to the realm of dealerships cutting corners. They do that constantly. There are maybe a handful of techs nationwide that actually do the job and explore all options, but most could give two shits...it isn't their car.
As for the CEL going away, I wouldn't worry about it. If it comes back, you know what to expect.
UM Stage II :: Rev. D OEM DV :: Podi Boost gauge :: Podi Oil press/temp that still don't work :( :: BSH Mounts all around :: Hawk HPS :: Neuspeed SS Lines :: Zimmerman Rotors :: K04 kit :: HPFP.
'06 GLI FSI - "Das Auto, Bitch."
alphabits is offline   Reply With Quote
Old 05-26-2014, 01:54 PM   #10
ier362
Drives: 08 GTI MKV
FYI -my car threw this code and p0171 when I forgot to stick the oil gauge in all the way :p
ier362 is offline   Reply With Quote
