Old 04-28-2011, 07:34 AM   #1
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
Spark plugs for k04
I've passed 40k and I've recently put in the k04 so I'm about to change my plugs do I use the factory ones or what?
xplicit is offline   Reply With Quote
Old 04-28-2011, 08:08 AM   #2
DarkX
Your Boss :P
DarkX's Avatar
Drives: GTI Edition 30 DSG
Send a message via MSN to DarkX
When I went for my tune the guys at REVO asked me and made it very important about whether I had recently replaced (not upgraded) my spark plugs. Told them yeah my new spark plugs don't have more than 500 km on them (few days prior to getting my tune I had my service done and replaced spark plugs), so they told me ok keep them since they're new, but get back here in about 10,000 km and we'll upgrade them. So yeah if you're due to replacing your stock you should upgrade as well. Don't remember exactly to what (they did mention it just don't remember) but tomorrow I'm gonna give them a call for some business and I can ask.
2007 Diamond Black ED30 DSG :: 370+ hp :: 460+ nm :: ECU REVO stage 2+ :: DSG REVO stage 2 :: Maxogen ITG intake :: Exhaustflow TBE 76mm :: HJS 200cell 130mm cat :: Autotech HPFP :: APR IC :: DV revision D :: NGK R8 coils :: NGK BKR8EIX spark plugs :: StopTech ST41 BBK :: Neuspeed drilled rear rotors :: Goodridge rear lines :: Toyo Proxes R888 tires 225/40/ZR18 (92Y) :: KW coilovers > BUILD | GARAGE | DYNO <
DarkX is offline   Reply With Quote
Old 04-28-2011, 08:44 AM   #3
JamDawg
Formula 5000 Champion
Drives: 2009 GTI
Stock plugs are all you need to run in thses cars.
Read Chris's response about going one step colder. Half way down the page.
http://www.golfmkv.com/forums/showth...k+plugs+colder
Only upgrade that you might make is upgrading to iridium plugs because they will last longer.
JamDawg is offline   Reply With Quote
Old 04-28-2011, 12:08 PM   #4
xplicit
FIA GT Champion
xplicit's Avatar
Drives: 09 GTI
He keeps talkin about stage 1 and 2 though so idk
Old 04-28-2011, 12:17 PM   #5
GTImarcus
Drives: 2006 gti
I'm recently went Revo k04 and the car has never been running right. No codes or anything and I have 50k miles and haven't changed my plugs..I don't know of this could be the reason but I'm running 5* of timing which is super low and dynod 277whp and 260tq
GTImarcus is offline   Reply With Quote
Old 04-28-2011, 12:27 PM   #6
JamDawg
Drives: 2009 GTI
Originally Posted by Chris@RT View Post
I've run 30+psi on my GT35R setup on stock plugs.
A stock turbo 2.0t doesn't need cooler plugs.
Way bigger than your KO4
Change your plugs and see. It only take 10 mins to change and cost a few bucks.
Old 04-28-2011, 12:29 PM   #7
GTImarcus
Drives: 2006 gti
how do i know about gapping and stuff though?
Old 04-28-2011, 12:40 PM   #8
JamDawg
Drives: 2009 GTI
Do a search on here to find the name of the stock NGK plug, buy, install. They are pre-gapped.
If I had to guess it sounds like you will need a spark plug socket as well.
I take that back, give me you K04, you don't deserve it
I'm kidding (a little)
Old 04-28-2011, 01:18 PM   #9
GTImarcus
Drives: 2006 gti
I actually installed my k04 and left the injectors to be installed at a shop :) I'm pretty knowledgable with most stuff on my car but I'm still learning
