Auto 4D DG springs with Bilstein B8's have a 1.5 finger gap and we'll have to see how it settles. The fender-to-wheel center measurement was 343mm front and 345mm rear so as far as I am concerned it is perfectly level when you take any irregularities in the road, car, and springs into consideration. This is with >3/4 tank of fuel and with the spare tire but without the jack and the rear muffler (have DG exhaust).
As far as I am concerned the 2D Auto DG springs are 6-10mm higher VW Racing springs according to the TUV specs and my own measurements.
The ride quality with the MkVI Bilstein B8 Sports is truly amazing and I don't throw superlatives around like that lightly. Feel free to check any of my posts on the MkV forum. I can't image a better set-up for road. At first I almost thought it might be too soft, but I think it is the difference in having a lot of buttery smooth travel. Not bottoming, no jarring, no head bouncing off the headrest from freeway seams. Just clean, tight, long travel with no on center vagueness and no bump steer from irregular suspension travel - much less corrections. I do have both sway bars but seriously it's a good set-up. I'm going to get another alignment after another week or two and really push it to write-up my impressions. The stock Sachs dampers are probably fine for most people... it's been so long since I've had them on my car, but the MkVI B8s are truly amazing. Make sure you don't make the mistake of getting MkV B8s they are 20% harder. I can get the exact damping values to you but lets just leave it that the new dampers are not harsh like the old ones. Highly recommended set-up for the real world.
