Thrust Sensor = CEL P0089
CaptainCalf
Lithia, FL USA
07 GTI
In case anybody has what seems like motor skipping and momentary power losses or some more pronounced fuel cut feelings while boosting and gets code# P0089 there's a high probability the Thrust Sensor on the high pressure fuel pump has gone bad.
From what I've gathered, the original part is susceptible to fuel intrusion and I think VW recognized it in 2008 with a technical bulletin and corrected the problem with the part. The new part has a new part number...RC
Blaster
South Florida
I believe this is what went on my car. It's at the dealer now. I got fuel cuts even off boost and at low throttle positions.
Code:
2 Faults Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
               P310B - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 10
                    Mileage: 56106 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:32:00
             Freeze Frame:
                    RPM: 1664 /min
                    Load: 47.4 %
                    Speed: 43.0 km/h
                    Temperature: 90.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
000135 - Fuel Rail/System Pressure: Too Low
               P0087 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 56108 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:36:18
             Freeze Frame:
                    RPM: 1448 /min
                    Load: 27.4 %
                    Speed: 18.0 km/h
                    Temperature: 90.0°C
                    Temperature: 48.0°C
                    Voltage: 13.716 V
CaptainCalf
Lithia, FL USA
07 GTI
Code:
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 10
                    Mileage: 56106 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:32:00
             Freeze Frame:
                    RPM: 1664 /min
                    Load: 47.4 %
                    Speed: 43.0 km/h
                    Temperature: 90.0°C
                    Temperature: 46.0°C
                    Voltage: 13.843 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 56108 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:36:18
             Freeze Frame:
                    RPM: 1448 /min
                    Load: 27.4 %
                    Speed: 18.0 km/h
                    Temperature: 90.0°C
                    Temperature: 48.0°C
                    Voltage: 13.716 V
I'd beat that it's a bad Thrust Sensor cuz it controls low pressure side...
$68 DIY, but pls let us know what the dealer charges...RC
julito04
I plead the fif.
STL
08 WRX Limited
$67?! Daaaaang. I got mine for $52 or something like that from the dealer when I had my APR pump. I guess prices have gone up due to necessity?
julito04
I plead the fif.
STL
08 WRX Limited
Well damn. Nothing like profiting off of an engineering flaw to make it a good day. Good job, VW. Lol.
Blaster
South Florida
They changed the timing belt tensioner under warranty and did the recall on the airbag sensor.
They did however charge me $107 to get the codes off my ECU... THAT I GAVE TO THEM ON PAPER. So basically they charged me for nothing. Can VWoA help me with this? :|
CaptainCalf
Lithia, FL USA
07 GTI
I doubt you'll ever get any of that $107 back, but for future reference auto parts stores such as Advance will read and clear codes for you for FREE!
RC
Blaster
South Florida
I have a VAGCOM and I took the codes out myself and printed them. I showed it to them and I told them that I thought it was the thrust sensor. They didn't hear any of it and charged me to "diagnose" my car . Which was just to get the codes off of it, that I left for them on the passenger seat.
The Fed
Old Guys Rule
Florida
Doesn't work that way. VW won't reimbuse from YOUR print outs. You can make a print out read mostly anything you want. Pull the connector off a coil and see what the print out reads. Doesn't mean the coil is bad.
