#1 |
Illuminati
![]() Drives: 2008 CW GTI MKV Join Date: Feb 2008
Need help finding this part. Any suggestions??
Last time I was working on my suspension I managed to mess up the easiest part of the swap and cross thread the bolt that holds the shock in place (I really do not know how I managed to do this). I would really prefer getting this part off of someone with a crashed GTI so I do not have to go through the dealership. Below are the pictures of the part im taking about:
#2 |
HEY TERRY!
you cant re-tap it?
9.5:1 JE Pistons, DM Forged H-beams, Calico coated bearings, ARP hardware, HEP Stage 3 intake manifold, Clutchmasters fx700 twin disc, AEM F/IC 6, FIC 1100CC aux injectors, RS4 primary injectors, APR Intercooler, FP HTA 3586R, Tail Q BOV, Tial 38mm wastegate, Bosch 044 low pressure fuel pump, APR HPFP, RS4 frv, VTA PCV, Turbosmart E-Boost2 EBC, Balance shaft delete, ETC
#3 |
Illuminati
Haven't really given it much thought. Also i've never retapped anything so I wouldn't even know where to start
#4 |
insert custom title here
![]() Drives: 06 CW GTI, 01 Jetta Wolfsburg Join Date: Jul 2009
Go to like a hardware store or fastenal with the bolt so they can match up the thread pitch and diameter. Get a handle with the tap should be about $20 at most. Keep the handle straight and turn it in back it off after a few turns when it gets hard to turn. Don't keep turning if its hard to turn you can break the tap that way.
| Thread Tools | |
