I have a set of folding mirrors probably arriving end of month and I have the switch. Sure they don't fold very much but I was after the oem puddles lights moreso.
You need the following part numbers
1K2 857 507 BA 9B9 Left Mirror
1K2 857 508 AE 9B9 Right Mirror
1K0 959 565 JREH Switch with folding
I am not sure about connections on pre 2008 vehicles but the loom should have correct wires for 2008+ vehicles, it is merely a vcds coding issue. I will confirm all of this and provide pictures when I am done with the mod
Beware, there are other models mentioned on my-gti.com which are incorrect. They are for LHD cars. These are RHD specific as stated in ETKA.
You will also need door controllers of at least revision N as in this one.
1K0 959 701 N
There are also letters after the N which determine whether it can do folding. I couldn't find more information on which ones did. A Vag Com scan will only tell you the revision Letter and no further information.
You will either need to take your door card off to inspect which is a good time to do door warning lights or use vag com and try coding for folding mirrors to see if it is out of range.
AFAIK the 2008+ cars will do puddle and door folding and will also do rear door warning in addition to fronts. Door warning lights are an excellent modification and cheap as well.
I will post pics and any problems that I may have when i install. Hope they are here when i return from Japan.
Booba.
