Ringer Racing
Old 11-27-2010, 10:35 AM   #1
Tomlins_Afro
Touring Car Champion
Tomlins_Afro's Avatar
Drives: TR '09 GTI, 2012 CC Sport
Tire Pressures
What tire pressures do you guys use for front and back on long road trips? (500+ miles) In cold weather would it make more sense to use a pound or 2 less than max because the tires heat up and the air expands?
GOLF XING
Tomlins_Afro is offline   Reply With Quote
Old 11-27-2010, 10:57 AM   #2
The Fed
Old Guys Rule
Drives: 2007 GTI DSG APR S1
That's probably not a good question to ask because many people have different preferences. You can't go wrong if you stick with the recommended pressures on the decal when the tires are COLD. Never adjust tire pressures just because it's cold or hot outside. Fill them with the pressure on the decal when cold. The tires will take care of themselves.
Tires will heat up regardless of the outside temperature when you drive. Probably about 3 PSI. Fronts heat up more unless you're driving/cruising in a straight line. And if the sun is always on one side of the car they heat up more. It's not possible to keep them where they "should" be. You're not supposed to compensate. If you're racing on an oval or autocross you do, but that's another story.
Personally, I lower them for a better ride.
Old 11-27-2010, 11:02 AM   #3
koyhis
AAAA!
koyhis's Avatar
Drives: Jetta VI
in cold weather you need more pressure 10˚c less = 0.1bar more
also when its cold i dont think the tires really heat up ??
Originally Posted by VW_gti_09
then i got called out by a cobra... i know better i told him id rather not feed my bunny to a snake...lol
koyhis is offline   Reply With Quote
Old 11-27-2010, 12:30 PM   #4
65dunebuugy
insert custom title here
65dunebuugy's Avatar
Drives: 06 CW GTI, 01 Jetta Wolfsburg
Difference tires have different temp ratings A,B,C with respect in the tires ability to dissipate heat
65dunebuugy is offline   Reply With Quote
Old 11-27-2010, 01:11 PM   #5
WickedLou9
I'm a geek
WickedLou9's Avatar
Drives: 08 GTI, BMP, 4dr, DSG, Revo 1
Over inflation is not much of a risk. Tires can withstand significant pressure without failing. they are usually hydro tested well over 100psi. the problem is that when you over inflate the tire rounds out, gets very stiff and you get poor tire wear. I would run 35-38psi measured when cold.
My fast thinks that 130 is perfectly reasonable.
WickedLou9 is offline   Reply With Quote
Old 11-27-2010, 01:21 PM   #6
Helistyle
www.lowmain.net
Helistyle's Avatar
Drives: 2006 GTI Candy White
I run anywhere from 32 to 35 all around the whole car, and I travel about 700 miles a week for work
Helistyle is offline   Reply With Quote
Old 11-28-2010, 12:22 PM   #7
NewToVW
Automotive Ninja
NewToVW's Avatar
Drives: 2009 GTI 4DR 6MT
If you're still on the original tires, go with the door jamb recommended pressure.
NewToVW is offline   Reply With Quote
Old 11-28-2010, 12:41 PM   #8
Helistyle
www.lowmain.net
Helistyle's Avatar
agreed best start off pressures
Old 11-28-2010, 01:13 PM   #9
nicksalsbury
SlamBurgled...
Drives: GTI MKV
I run 40psi for longer trips (max 600 miles)
I'm so sorry...
nicksalsbury is offline   Reply With Quote
Old 11-28-2010, 05:54 PM   #10
1972vw
FIA World Rally Car Newbie
1972vw's Avatar
Drives: 2009 GTI
Just run the pressures that are on that sticker in your door jamb.
1972vw is offline   Reply With Quote
Old 11-29-2010, 01:31 AM   #11
Nazty Nate
Oval Champion
Drives: 2008 GTI
I run about ~36-38 psi on all 4 wheels (thats measured cold), recommended according to vw on my doorjam is 35.
APR K04 * EJ FMIC * KW V3 Coils *
Nazty Nate is offline   Reply With Quote
Old 11-29-2010, 02:17 AM   #12
TheeFT
That One Guy
TheeFT's Avatar
Drives: 2007 RS Rabbit
Send a message via AIM to TheeFT
for daily driving i run 36 because the tires aren't heating up enough in stop in go traffic like city driving. for longer trips, like turnpike, i like to run a 34 because they the tire will heat up and expand the air inside, maximum grip occurs at 36psi, so when track days or anything like that 32psi giving me 4psi to expand but each tire expands differently some it could expand only 2psi under heat so you would want to run a 34 to achieve 36
Schaeffers Oil
TheeFT is offline   Reply With Quote
Old 11-29-2010, 02:44 AM   #13
spartanrabbit09
ask me about my wiener
spartanrabbit09's Avatar
Drives: 09 UB MKV Rabbit
+1
just make life easy
spartanrabbit09 is offline   Reply With Quote
Old 11-29-2010, 09:25 PM   #14
Tomlins_Afro
Another thing... I keep getting a low tire pressure warning every time I start the car and a warning light stays on all the time alerting me to the "problem." I put problem in "" because I have checked and rechecked the tires numerous times in numerous conditions and the pressure is never more than 1 lb less than the recommended setting on the door. Do I have to bring it in to the dealership to clear the "fault?" (I don't have access to Vag-Com)
GOLF XING
Old 11-29-2010, 09:37 PM   #15
The Fed
Old Guys Rule
Pump the tires up to 45 or 50 and see if the light goes out. If so, bleed them back down to 38. They not that sensitive, they can't read within a few pounds.
If that doesn't work you may need a new sensor(s) due to bad batteries.
No fault to clear. You need your own VCDS to disable or reset tripping pressures, dealer won't help you.
Old 11-29-2010, 11:52 PM   #16
Wazzap1101
FIA World Rally Car Champion
Wazzap1101's Avatar
Drives: 2007 VW GTi DSG
Try 35-38 psi. The tpms should def turn off at that pressure. For cold weather, Im at 33ish psi. Works great for me in the NY cold
Wazzap1101 is offline   Reply With Quote
Old 11-30-2010, 12:14 AM   #17
VancouverGTI
Formula 3000 Champion
VancouverGTI's Avatar
Drives: 2009 GTI w/DSG
Check your spare. If it's a full-size, anyway.
VancouverGTI is offline   Reply With Quote
Old 11-30-2010, 05:45 PM   #18
The Fed
Old Guys Rule
I don't think the spare will trip the sensors unless you recently had it on the car. Mine was low and it didn't trip.
Old 11-30-2010, 06:11 PM   #19
silversleeper
Retired OG
silversleeper's Avatar
Drives: .
silversleeper is offline   Reply With Quote
Old 12-01-2010, 06:02 PM   #20
stuck24
so?
Drives: 2010 CW GTI: 6spmanualtranny
my mk6 tire pressure recommendation is 38 psi. I think this is too too stiff and is done for newer gas mileage standards. Older GTIs with the saem Huff wheels were running 35 psi.
I run my mk6 at 36 psi cold pressure. Nice compromise !
stuck24 is offline   Reply With Quote
Old 12-01-2010, 06:06 PM   #21
RevoGLI
i <3 canada land
RevoGLI's Avatar
Drives: 2.0T FSi
yes they do, it's called friction.
RevoGLI is offline   Reply With Quote
