siliconcenturion
- Norcal, 94043
I've come up with a fairly simple way to turn your OEM ipod dock (which most people consider useless) into a standard Aux-in jack using the OEM parts and locations. The total cost should be <40 dollars for parts.
It fits right into the OEM placement, which all ipod armrests should have:
(not my picture)
NOTE: THIS WILL NOT WORK IF YOU HAVE A PREMIUM7 WITHOUT SILVER BUTTONS
If you have a Premium7, this mod will require a VAGCOM and some simple coding.
If you have an RCD510 or RNS510 retrofitted from a Premium7 (for instance, by following my previous DIY), you will need to remove the head unit and re-wire one of the connectors, but no re-coding should be necessary.
What you need:
OEM VW parts:
Aux socket - 5M0-035-724
Aux socket plug body - 8K0-973-754
Wire leads for aux socket plug ( need 2) - 000-979-009-EA
Ipod plug body - 6Q0-972-736
Ipod plug body wire leads ( need 2) - 000-979-123
Total cost should be around ~40 shipped from 1stvwparts.com or genuinevwaudiparts.com
Tools:
-Soft plastic trim removal tool
-Electrical/fabric tape
-T15 screwdriver
-Wire stripper/crimper
-Wire butt crimps OR soldering iron+solder
For Premium7:
-VAGCOM
For RCD/RNS510 retrofit:
-Un-bent paperclip to remove terminals
Building the harness
Start by collecting your OEM parts. Take the Aux socket and set it aside.
Take the Aux socket plug, 8K0-973-754, and stick the ends of the 2 aux socket plug leads, 000-979-009-EA, into the plug body (so the leads are looped). Press down on the locking part of the plug and cut the loops.
Mark the wires as such:
Now, take the ipod harness plug, 6Q0-972-736, and plug the ends of the wire leads, 000-979-123, into pins 7,9 and 10. These pins numbers are specified on the sides of the connector. When the leads are inserted, snap the locking mechanism into place, and cut the wire loops.
Mark the wires as follows:
Cut the ends of all of the wires to about 5" length from the plugs (so we dont have extra slack to rattle around) and strip the ends of the wires
Insert the matching ends into the crimps and crimp them with the wire stripper tool or pliers. Make sure the wires are firmly crunched into the crimps.
Your harness is done
However, I originally made my harness too long, so I cut the wires to the shorter size and ended up soldering them together, which gives a much cleaner harness
Then, I covered the harness in fabric tape for an OEM look and to minimize rattles, and it was ready to be installed.
Installing the harness
The center armrest cover must be removed. I swapped my ipod-style armrest, for a big-cubby one, so some of the steps are different for mine.
Remove the two screws holding in the rear cupholders:
Pull the cupholder out by rotating the top out of the armrest first
Now, the back plastic part of the armrest with the vents will come off
put your fingers (or a trim tool) in the gap and pull outwards and backwards until the plastic piece comes off
Remove the two screws on the back
Now, remove the ipod dock. You can do this by prying around the edges with the trim tool until the dock pops upward. After the dock is released, there will be a screw towards the front of the armrest that can now be accessed. On my armrest, this is what the screw looks like. It will be in the same place on the ipod armrest
(not my picture)
What you need:
OEM VW parts:
Tools:
-T15 screwdriver
For Premium7:
-VAGCOM
