Hi.
Could someone give me some instructions how to remove trunk interior?
Thanks.
If you follow the procedure in the Bentley manual to remove the two carpeted side pieces, it is a really big job.
On a two door, includes removal of the lower trim around the hatch opening, rear load floor,
lower A-pillar cover, door sill trim, rear seat upper and lower cushions, upper B-pillar trim, the side cards in the back seat.
All of that gets you access to otherwise hidden screws holding the rear compartment side covers.
made this pic for someone else - the spot marked "still need to remove this one" is the fastener hidden by the rear seat side card.
Which then provides clearance for removing the carpeted side pieces.
Clearly there are workarounds, but that is the documented factory procedure to remove those two pieces.
I removed them while adding additional wiring to the car.
