I'm looking to buy a used 06-07 MKV GTI as a daily driver. Have you guys had any reliability issues with your golfs? If so, is it cheap to repair? Your input is appreciated!:thumbup:
Well nobody has mentioned the reason why I went from a GTI
to a Mustang GT.
The GTI has an open differential which results in a lot of front wheel (one wheel) spin from a stop if you drive in a spirited fashion. If you get upgrade your ECM to an aftermarket reflash then the problem only gets worse. (Yes I had summer tires on Hufs)
I have been told that I just need to be more mindful of my throttle application. :clap:
To me that is just a band-aid, not a solution.
Be sure to thoroughly test drive a GTI and see if it is right for you.
And to answer your question, no a GTI is not inexpensive to repair. Oh and be prepared to by specialized tools if you do your own wrench turning. (DSG fluid service, Triple-square tool bit for a simple brake job, etc)
