Old 03-11-2010, 02:23 AM   #1
aqeel27
aqeel27's Avatar
Drives: 07 GTi
Help! Hood wont close!
I opened my hood to check oil levels after getting out of work but the dam thing won't shut. I have a feeling I pulled the lever too hard from the cabin which may have caused the cable to get loose?
Any ideas on how I can resolve this issue asap witout having to resort to the dealer? The car isn't under warranty anymore so duno how much the stealership wud charge
Need to get this resolved asap
CW - Stage 1, 6spd, euro switch, nokyas, blue batmobile's roof and tail overlays, BSH True Seal, BSH DV relocation kit, Forge Diverter Valve
"All muscle cars are crap" -- Jeremy Clarkson
aqeel27 is offline   Reply With Quote
Old 03-11-2010, 02:26 AM   #2
Dan GSR
Dan GSR's Avatar
Drives: 06 GTI
Send a message via AIM to Dan GSR
latch height needs to be adjusted
Dan GSR is offline   Reply With Quote
Old 03-11-2010, 09:49 AM   #3
aqeel27
aqeel27's Avatar
Drives: 07 GTi
lol, how do I do that?
Old 03-11-2010, 09:56 AM   #4
Dan GSR
Dan GSR's Avatar
Drives: 06 GTI
remove the grill
then there are 3 t30 torx screws that hold the latch
Old 03-11-2010, 10:12 AM   #5
aqeel27
aqeel27's Avatar
Drives: 07 GTi
I asked my friend yesterday to look at the mechanism and see if any of the parts move while I move the lever up anddown. we heard the cable noise but nothing moved
Old 03-11-2010, 02:18 PM   #6
JZMKV
JZMKV's Avatar
Drives: 09' CW TSI
try using a screw drive to push the hood lock down if it locks then the latch is still working. in which case dangsr would be correct in adjusting the height. if it wont lock the the lach its done.
if the cable is moving and nothign is happening sounds like it is open, maybe you need to slam the hood rather then closing it and then pushing down till the latch catches.
TSI CCTA
//APR//H&R//Koni//Forge\\EVMS\\L.E.D.\\
JZMKV is offline   Reply With Quote
Old 03-11-2010, 03:20 PM   #7
aqeel27
aqeel27's Avatar
Drives: 07 GTi
thanks for the input guys, the latch on the hood was stuck and needed lube. I guess sometimes the problem is staring at you in the face lol
Old 01-02-2013, 12:53 AM   #8
PaNO
Touring Car Champion
Drives: 2007 CW GTi
Send a message via AIM to PaNO
Hey guys,
Great information.. if the hood latch is broken, then is it an easy replacement or I need to bring it to a shop?
Thanks
PaNO is offline   Reply With Quote
