I searched..valve cover gasket install?
Adrian06GTI
Austin TX
I'm leaking oil around the valve cover gasket area, I do see that many have had the same problem but I couldn't find a diy on it..I'm sure it's simple - I've pulled engines before, but I haven't opened up an engine newer than 1987!
Anyone got a walk thru on it? Pretty sure just the gasket needs replaced..
65dunebuugy
insert custom title here
Iowa
its pretty easy just:
1: unplug the coil pack connectors
2. remove coil packs
3. remove top timing cover
4. remove nuts and bolts
5. clean
6. install new gasket
7 do 4-1 in reverse
I think this is most of the steps needed for to install a new valve cover gasket
julito04
I plead the fif.
STL
08 WRX Limited
Make sure theyre torqued correctly.
conneem
Ireland
h0ckeyfreek20
Northern NJ
Anyone have any idea what N/m or lb/ft the bolts need to be tightened to?
10Nm
or
about 7.5 ft/lbs
definitely use a torque wrench on this
siliconcenturion
Norcal, 94043
Second time I've posted this:
The Fed
Old Guys Rule
Florida
Intersting it's spiral then corners. I would have thought it would be center bolts first then work your way to the ends.
h0ckeyfreek20
Northern NJ
5. clean
7 do 4-1 in reverse
you make it seem so simple, its just gonna screw people over because torquing the bolts is the most important part.
thank you
Cornbread
Melbourne FL
what happens if they r too tight?
Jtrem
Pro TeaBagger
SoCal
'06 Gti
I did mine. Really isnt tough. Just make sure you have a torque wrench and take your time putting the bolts back on.
Mine was leaking as well and holy shit the previous owner or dealer had torqued the shit out of them. The vavle gasket was actually flattened in some areas from being on so tight.
I think it was leaking and the tech was like, "hmmm lets torque the shit out of it... should work."
Cornbread
Melbourne FL
So essentially if I put new plugs in and I already have a catch can and I pull my plugs and there is oil on the threads I should replace the gasket?
