So, here is a simple DIY for those who's tires only rub a little bit
dpham00
Modérateur Emeritus
Los Angeles, CA
This DIY will help reduce or eliminate rubbing, depending on how bad you're rubbing in the front. The nice thing about this is that it's completely reversible, and doesn't require any cutting.
So, just look near the top the fenderliner. you'll see something like this:
Tools i used:
-1/4" socket wrench
-1/4" socket
-torx t-20 bit
-cutting plier
You can use any thing with a t-20 bit, but i found this to be easiest for me.
-Unbolt the screw
-Tuck the plastic behind the metal tab. You will have to use some force to do this.
-Use the cutting pliers, and lightly grip around the screw retainer in order to pull it out.
The removed pieces should look like this:
And here is what the fender should look like after you're done:
Now, if you're still rubbing after doing this, then try this:
http://forums.vwvortex.com/zerothread?id=2514372
alf
Modwhoreator
Houston, TX
2006 TR GTI
i did the same. completely got rid of it, crazy what not even 3mm of clearance can do to rubbage.
jonnyc
Newbie
UK
This is exactly what i needed!!
Im on coilovers lowered around 40mm, with rubbing as soon as i thought about driving quickly! Did this fix and was able to lower my car a further 20mm and I havnt rubbed once since!!
Thanks!!
Jonny
Ballinfrogs
Miami Florida
damn...amazing what so little can provide
Big Jerm
Autocross Newbie
Tennessee
2006 GTI
ok i see where you put the plastic fender well above the metal flap, did you bend it further up and did you reassemble it back the screw and screw retainer?
g60_corrado_91
IL
2006 GTI 6MT Pkg 1
Darn, I may still rub even with putting the plastic up there because I've already moved the screws and just kept the plastic there, and I know I rubbed on the plastic yesterday during hard cornering. I have the Sport Cupkit (2.2 F) with 18x8 rims ET45 and 225/45 tires, so I'm sure that's part of the culprit. And I don't feel like cutting anything, nor do I want it rubbing on the metal part, so I'll probably just deal with the really minor rubbing (only on hard cornering and big dips).
g60_corrado_91
IL
2006 GTI 6MT Pkg 1
well, you can try to fold the lip, but be careful as doing so can cause paint cracking if not done correctly.
Yeah, I was thinking about that, but I may as well deal with the rubbing because paint cracking is 10x worse than rubbing only on hard cornering or big dips. And I don't think I'm going to rub on 16x6.5" steelies with 215/55/16 winter tires. Yeah, I know 205/55 is preferred, but my sister sold her Grand Prix and it had 215/55's winter tires on it, so I figure the extra cm isn't going to hurt for 4 months or so.
