The one lug that just didnt want to go
awb17x
WHEEL Slayer
Bpo/CT
2006 GTI
Cliffs: I broke the key in the lug... Than broke a tap in the key ( tap =titanium) ... used all drill bits, easy outs.. nada.. worked.. soooo
^ type of lug I had
It got really dark out... :laugh:
Enjoy :laugh:
KkSc
TS Auto Design
W.Vancouver/ Hong Kong
Audi B7 2.0T/ VW MkV
ouch..you actually needed to cut the spokes to take it out?
awb17x
WHEEL Slayer
Bpo/CT
2006 GTI
I did what they all said plus some... Here is was I tried.
*welded extention to lug* ( I could only do half of it because There wasnt any room to ge to the bottom, that broke)
*easy out* Didnt really work since drill bits are brass
The lug tool that they are talking about... yup... That didnt fit inside the hole because it was way to small. As you can tell in the 1st pic
Drilling may have work had the tap not been titanium.
vdubya 6
cant spell or tipe!
jersey
what about welding a 3/4" bolt to to it and buzzing it off w/ an impact. ? i know you t said you couldnt weld it all but it shouldnt take thar much weld to take off 90 ft. lbs
and an air chisle works some thines too
awb17x
WHEEL Slayer
Bpo/CT
2006 GTI
We used a impack gun to try and take it off ... nada. When I took it to the shop to get the weld put on it kept snaping since they could only get half of it.
GoodFast08
Give it the beans!
IN
2008 GTI
hahaha "so dont buy a vw."
All you had to do was weld a NUT onto the lug bolt. You weld the inside of the nut to the lug. Pretty retard proof.
