GolfRS
- Europe-Greece
Well for those of you that have been waiting for this, it's
finally here.I have no knowledge of the actual release date, but for the past month i have installed and tested one of the few existing Forge K04 actuators out there, and this thread will contain my thoughts and findings, along with (of course) graphs and numbers.I will be updating this slowly with more data and pics.
For starters, the actuator itself.It has similar appearance to the K03 actuator, but the bracket is somewhat (a lot ?) different.The mounting holes on the bracket don't line up like in the K03 version, so you definitely need this if you have a K04.
Compared to the OEM actuator, the actual threaded part of the actuator is shorter.Having played with the nuts (the actuator's of course) the OEM actuator is pretty uselessly long, since Forge's length pretty much matches the opening range of the wastegate itself.
Installation was indeed a b*atch, as mentioned with the K03, but maybe even more so cause of the slightly different holes.I'm pretty handy with the wrench, but still i don't regret going to a shop for it (read further down to see why..).
After talking to Forge, i was instructed to try the Blue spring first, which AFAIK is the second hardest after the Red, and one hardest than the Yellow (the spring Forge uses for the K03 version also).I had been experiencing high N75 values at redline, and my reasoning was the excessive exhaust gas volume was pushing the wastegate open.When the install was over, i set the nut at almost OEM position and went for a run, but it so proved the Blue spring is TOO HARD for this turbo, and i wasn't ever able to control boost in an orderly fashion...
That meant the next possible spring was in order, which was the Yellow one.This however posed a HUGE problem, cause i seriously didn't want to redo the whole process, so i decided to remove the spring ANOTHER WAY...Don't ask me how, but i finally did it, and i don't wish it on anyone.So if Forge sends it with the Yellow spring....you leave it at that....
