Old 11-03-2009, 10:38 AM   #1
ard
FIA World Rally Car Champion
ard's Avatar
Drives: '06 GTI, 6MT
APR DP Routing
just wanted to check on something that i've been wondering about: if you look below the intake heatshield at the downpipe... should it be centered in the tunnel that runs under the car? this is a horrible picture, i know, but mine definitely isn't centered... its off to the right in this pictures orientation and its up against the heat shield
my other concern is that when i was torquing down the VF mounts, the front end of the car was in the air. i know thats not ideal, but could it cause issues?
Andy
APR Stage 2+ | APR RSC TBE | Neuspeed P-Flo | APR HPFP | Oettinger Kit
Eibach Pro-Kit | Koni Sports | H&R 24mm RSB | Neuspeed Endlinks | VF Mounts
42DD Catch Can | 42DD Shift Bushings | Neuspeed FMIC | NS TB Pipe | Rev D DV
Neuspeed SS Lines | EBC Redstuff | Newsouth Triple | Stinger SPV44 | 15% Tint
Alpine CDA-9887 | RF T400-4 | RF T500-1bd | Focal 165 K2P | JL 10w6v2 SB
ard is offline   Reply With Quote
Old 11-03-2009, 12:39 PM   #2
GolfRS
Drives: GOLF V GTI
There was an issue with "older" APR DP's being offcentered and touching the firewall.Mine did, and it was the "fixed" support version.
APR replaced it for me cause it was starting to eat away at the flex joint.
Take some better pics and send them to APR to see what they say....
GolfRS is offline   Reply With Quote
Old 11-03-2009, 07:27 PM   #3
Voyles
Twisty Champ
Drives: 2008 CW GTI
Send a message via AIM to Voyles
Same here.
GREAT SERVICE!
My money pit has stuff!
Voyles is offline   Reply With Quote
Old 11-03-2009, 08:36 PM   #4
ard
ard's Avatar
are you guys talking about the RSC exhaust or the earlier APR exhaust? cause they told me that that is the "normal" routing...
Andy
Old 11-04-2009, 10:21 AM   #5
GolfRS
Drives: GOLF V GTI
AFAIK RSC is all about the cat back section.
The downpipe, if it is the version with the tightening nut, then you can easily shift it a bit.
The problem existed with the older fixed version that contacted the firewall.
Old 11-04-2009, 10:32 AM   #6
ard
ard's Avatar
from what i can tell i think the only adjustment would be to unbolt it at the dp gasket and use the play in the bolt holes to angle it downward a little more. is that what you're talking about?
Andy
Old 11-04-2009, 10:55 AM   #7
GolfRS
Drives: GOLF V GTI
No no.
There is a medium sized bolt that connects the DP to its support.That bolt can move up/down and kinda sideways since the slit in which it moves is not vertical but also goes from left to right.That is the only adjustment you can do.
Oh, and there shouldn't be any "play" in the DP bolts to the turbo...
Old 11-04-2009, 10:57 AM   #8
utekineir
Drives: Hopped up toaster and a tdi
Send a message via AIM to utekineir
i have the rubbing version of the apr dp, its rubbed a hole in the flex pipe,
really need to get that taken car of, but.. really don't feel like going under the car either.
utekineir is offline   Reply With Quote
Old 11-04-2009, 11:52 AM   #9
GolfRS
Drives: GOLF V GTI
Well there is no other way to remove a DP AFAIK...
Just contact APR and see what they tell you.
For me, i just caught it in time.It wasn't pierced, but was getting there...
Old 11-04-2009, 11:54 AM   #10
ard
ard's Avatar
i'm not impressed APR
Andy
Old 11-04-2009, 11:57 AM   #11
GTIWV
WV VW
GTIWV's Avatar
Drives: 08 GTI, 02 S2000, 00 CRV
Send a message via AIM to GTIWV
your not impressed because your to fucking lazy to get under the car and take the dp off so they will send you a replacement section? what the fuck.
'08 CW GTI
APR K04
GTIWV is offline   Reply With Quote
Old 11-04-2009, 12:03 PM   #12
utekineir
from what i've read i'd say apr has handled it quite well, if send a replacement part to affected customers that resolves the issue what more could you really ask for?
my own personal laziness has nothing to do with the way apr handles the issue.
Old 11-04-2009, 12:29 PM   #13
ard
ard's Avatar
oh look, an internet tough guy. why don't you READ THE THREAD. i already talked to apr and they didn't offer to get me a replacement. they said that that routing is "normal". thanks for your help
Andy
Old 11-04-2009, 02:39 PM   #14
GolfRS
Drives: GOLF V GTI
For APR have been excellent about this.
Maybe another company wouldn't handle it as well...
I have to say they were lucky though,to have a detachable curving section, or else they would have to replace the whole cat also, and thats $$$$$ money....
