Parts4Euro
Old 10-11-2009, 07:23 PM   #1
white ride
white ride's Avatar
Drives: CW 2008 GTI FSI BPY
Post DIY: Removing side mirror housing and side mirror lens
I just replaced my car's side mirror lens and thought I'd share pics/steps on how to do this. I know there are a bunch of DIY out there but hopefully this will still be valuable. This works for removing the side mirror housing as well. It's not difficult but do this at your own risk, I'm not responsible if you break something ;P.
The time to remove this varies with your skill level or how anal you are. It can take between 10 to 30 mins for one. Older cars will probably have slightly more stubborn internals.
I bought black/smoke in.pro side mirror lenses to add to my car's ongoing motorsport look.
Before you start there are a few things you need to know. There are a total of 6 screws that you will need to remove. They are different lengths and heads. So I made sure I segregated them and remembered where they were used.
Also, on my 08, the OEM side mirror lenses had felt strips (adhesive back) while the in.pro. ones did not. I decided to just to transfer them to the new one.
You'll also need a Torx #10 tip screw driver. Angled tip probes are optional for the removing the tabs.
Before -- OEM clear looks good for OEM+ look or chromed/polished wheels or look:
After -- I'm going for the motorsport look:
Screws, there are six. Three different kinds, make sure you put them back in the same location:
You'll need a Torx #10 screwdriver. I already had a tip. Some are just screwdrivers:
OEM and in.pro. side by side:
OEM has a black felt strip while in.pro has none. It's up to you but I decided to move it to the new one:
Tilt mirror up using controls until there is a gap:
I used a screwdriver wrapped in cloth to gently pry the mirror off. Slip it under the gap. Just don't rush here. You don't want to scratch your mirror housing or break anything behind the mirror. It's not that hard.
Use your Torx #10 screwdriver and remove these:
Unplug these. Don't tug too hard. The one with the connector/adapter is a bit tricky. Remember the positive and negative wire locations on the mirror:
Here is the first tab that connects the side mirror lens to the mirror housing. You'll need to untab this. I used an angled probe, others use screw drivers. Just take your time.
Inside that hole is the second tab. It's a bit more trickier. I used an angled probe for this. Some use screwdrivers:
Once those tabs are removed, I gently pulled out the underside of the mirror housing so I can remove it:
Once the housing is removed, squeeze these tabs to pull/slide out the plastic strip.
Unscrew these:
Detach base and disconnect cable/wire from OEM side mirror lens.
Connect new side mirror lens or side mirror housing. Start reassembling side mirror in the reverse order:
Just be patient, gentle and clean it up after.
white ride is offline   Reply With Quote
Old 10-12-2009, 07:33 PM   #2
Tpass
FIA GT Newbie
Drives: 08 BMP 6M GTI
Nice DIY,
Have always wanted to change these out but new they were kind of a pain.
not so much now.
Thanks
Tpass is offline   Reply With Quote
Old 10-31-2009, 08:47 PM   #3
nismo23
Drives: 2007 Jetta FSi Revo Stage I
Great write up too..Should be stickied IMO...As with most useful DIY's
nismo23 is offline   Reply With Quote
Old 10-31-2009, 09:03 PM   #4
Mariach
FIA F1 World Champ..to be
Mariach's Avatar
Drives: 2009 BMP GTI DSG
I did this, before the write up, this would of been helpfull! The only issue i ran into was when removing my drivers side mirror, i broke one of the small tabs and now the mirror does not sit perfectly, there is a small distortion in the mirror. Not bad, but annoying. i love the black markers on my bmp. It's much more stealth.
Think very carefully, because if you ever start, you will never be able to leave it alone.
Mariach is offline   Reply With Quote
Old 11-07-2009, 10:31 AM   #5
bwen
FIA World Rally Car Champion
bwen's Avatar
Drives: MKV GTI Pirelli
Great DIY! Thank you
k04 :)
bwen is offline   Reply With Quote
Old 11-07-2009, 11:07 AM   #6
TwentyonePSI
Crody
TwentyonePSI's Avatar
Drives: E91 BMW 6MT, Stage 2 MKV 6MT
Nice write-up
TwentyonePSI is offline   Reply With Quote
Old 11-13-2009, 02:30 AM   #7
jcman7286
Drives: 2009 GTI UG
Great write up! Helped me out tons!
jcman7286 is offline   Reply With Quote
Old 11-13-2009, 03:38 AM   #8
cosedsc
EE Militia
cosedsc's Avatar
Drives: MK5 GTI
nice write up
cosedsc is offline   Reply With Quote
Old 11-13-2009, 03:50 AM   #9
HyeWarrior
Drives: E46 aka douchemobile
Send a message via AIM to HyeWarrior Send a message via MSN to HyeWarrior
Thanks!
And pics of the ISF please :)
HyeWarrior is offline   Reply With Quote
Old 12-30-2009, 05:10 AM   #10
ccmorange
Newbie
Drives: Golf 6
Hi, does anyone know how about to remove the door panel? since I had crash my mirror and would like to change by myself.
ccmorange is offline   Reply With Quote
Old 01-01-2010, 01:06 AM   #11
POLARBEAR666
FIA GT Champion
POLARBEAR666's Avatar
Drives: Golf GT TSI
Nice work!
*Disclaimer: nothing I say should be relied upon // Click the links for pictures
Dynolicious 6.89 to 100kph 0.8g max 143kw// KW V1 Coilovers// Custom Intake// Deleted Muffler// Deka ETX18L battery 8.2kg 720CCA// Weight Reduction ~50kg
POLARBEAR666 is offline   Reply With Quote
Old 01-01-2010, 11:10 AM   #12
-GT-
-GT-'s Avatar
Drives: GT 1.4 tsi -06
Great DIY, thanks! Can't wait to get smoked in.pro side mirror lenses
-GT- is offline   Reply With Quote
Old 02-16-2010, 11:39 PM   #13
white ride
white ride's Avatar
Thanks all, glad it's helpful
Originally Posted by HyeWarrior View Post
Thanks!
Don't have a lot of pics of it, but here is one:
Old 05-14-2010, 11:19 PM   #14
KingOfBattle
Touring Car Newbie
KingOfBattle's Avatar
Drives: 2008 VW GTI FSI
Thanks for the diy. Used it today, worked great.
2008 GTI FSI
KingOfBattle is offline   Reply With Quote
Old 06-21-2010, 03:23 PM   #15
MKVinthe702
Drives: 06 GTi
you are a saint. I saw some other post and it led me to break my mirror. this is an incredible write up thank you.
MKVinthe702 is offline   Reply With Quote
Old 12-12-2010, 08:19 AM   #16
r_fethi
Drives: Golf V 1.4 TSI 122 hp
Thank you. I changed the broken left mirror signal reflector.
r_fethi is offline   Reply With Quote
Old 01-18-2011, 06:13 PM   #17
Vins25
Dump Valve 7000RPM
Vins25's Avatar
Drives: MK5 GTI '08
Thank you so much man , cracked the glass of my lens , gonna get a new one now and replace it :)
GTI RS 2008 BWA Engine
Upsolute Chip Tunning
Originally Posted by TwentyonePSI View Post
I own 3 cars, but only have a 2 car garage.
Stage 1+ - Remaped (UPsolute) , Forge DV , EuroJet CAI
Vins25 is offline   Reply With Quote
Old 02-01-2011, 01:41 AM   #18
rodeopunk_je87
Silver Sleeper
rodeopunk_je87's Avatar
Drives: '11 Evo & GSX-R600
Great write up bump. Just ordered a replacement driver's side mirror indicator lens. Gonna need this.
Johnny
Stage 2
rodeopunk_je87 is offline   Reply With Quote
Old 02-24-2011, 07:01 PM   #19
thechromecoyote
FIA GT Newbie
thechromecoyote's Avatar
Drives: 2006 CW FSI GTI
Send a message via AIM to thechromecoyote
bump for a great write up, just did this today, and its really not complicated at all thanks to this. Took me about 45 minutes to swap both sides.
thechromecoyote is offline   Reply With Quote
Old 06-30-2011, 02:49 PM   #20
Rafał
Newbie
Drives: MK5
Where's that tab?!
EDIT: Nevermind, I have finally untabbed it (kinda hard with a scewdriver) and successful completed installation. Thanks for the DIY!
Rafał is offline   Reply With Quote
Old 07-05-2011, 06:16 PM   #21
Bsherb34
Bsherb34's Avatar
Drives: 2007 Volkswagen GTI
Bump for great write up... Just did mine... Perfect directions... Good write up!!
Bsherb34 is offline   Reply With Quote
Old 07-17-2011, 09:12 AM   #22
Pablos007
GTi Black Magic...
Pablos007's Avatar
Drives: 2006 GTI Stage II
Great write up. Thanks.
Pablos
2006 Mk5 GTi with some nice mods.....
Pablos007 is offline   Reply With Quote
