Look, i really don't want to argue with you, but can you explain to me how sure are you that they are identical?
You spread here these informations...... peoples will keep in their mind and when they really notice the difference start screaming here...
They will take updates file from internet try to update their units and after that will start asking desperate here for help.
If you are so sure of statements, i will give you AS7608 mainbord firmware to put on your AS8601....after that you will :fighting0030: me because you will screw your unit...Wanna try?:23:
AS7608 and AS8601 ARE NOT IDENTICAL!!!! they are based on same platform but not identical!
@Mindrunner
You are NOT the ONLY ONE who knows about this fucking crap HERE so i would like More Respect from you ,Is this Clear ?
Now
1) the hardware ( main board ,DVD loader ,screen panel ,gps board,bt module,tv tuner ,etc., except can bus module ) is EXACTLY THE SAME in both devices.
2)the firmware IS NOT ( cause firmware for AS7608 has a CAN-BUS MODULE >2009 with a lot of NEW functions and diferent code) ,and AS-8601 a downsized firmware and older CAN-BUS MODULE 1998-2005 ..So these are incompatible ,...
3) The WinCE 6.0 OS is identical in both devices ( Samsung ARM11)
and for the end I never ever said devices are identical , just said Almost have the same hardware except can bus
